Synthetic Oil
Oil of Choice
  • Castrol Syntec/Edge
    Votes: 237 8.5%
  • Royal Purple
    Votes: 327 11.7%
  • AMSOil
    Votes: 401 14.4%
  • Valvoline Synpower
    Votes: 161 5.8%
  • Mobil 1
    Votes: 997 35.8%
  • Other
    Votes: 664 23.8%
  • Total voters
    2,787
Bigpaul13
I'd trust it, but then again with the new synthetic media "super filters", are they really necessary?
Right, I would most likely run a single filter kit if I went that route mainly to make changes faster.
I was reading a post (on here I think) of someone who had a failure while driving. I know there's different kits with different qualities so I gotta look more into this.
Hemi395
Cape Cod MA
It doesn't surprise me, a relocation kit adds hoses and connections that are potential failure points.
While I like the convenience and added filter options I just haven't been able to pull the trigger on one yet...
Michael
In an undisclosed bunker
Yea I was looking into them but since covid came about, I'm not driving nearly as much. Looks like I might be down to one oil change a year. At that rate I would probably leave it stock. For some reason I don't trust it. I know guys run it without problem but in my mind, I don't want to be in a remote spot hunting or fishing and have an issue.
I haven’t done one either because I don’t trust them either. Just one more thing to fail.
Zoe Saldana
california
6.4l
Yes.
I don't find changing the filter problematic.
The design that is off is the drain hole. It is a large rectangular shape so the oil drips all over the place from a high place.
A smaller round hole would help to better direct the oil into the oil pan.
I have the below. I put a large funnel in it and I can drain the oil directly from the oil pan and filter into it.
https://www.amazon.com/Hopkins-11849-FloTool-Dispos-Oil-Recycle/dp/B0014FKI1Q
I have a 6.4. I don't know if the 5.7 has the height for it.
Remote filters are common in the Semi Truck world,and last several hundred thousand miles with no issues.
If you use quality reinforced hoses,and a decent remote kit,you shouldn't have any issues during the life of the truck.
Yeah, but that's like only one year in a rig, lol. I used to do 75,000 to a 100k miles a year, and I know many many guys who do more, my buddy does at least 150 more miles then I did everyday. Yes those bypass setups can actually extend the life of an engine, which I'm not sure a gas relocate kit will, even if it is double filter. It might, but a bypass filter is the real deal. I still trust the setup of relocate and they are cool, but I don't really know what the big deal is, changing the filter isn't that hard imo.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
Big engines like the 3,000hp+ I worked on in the powergen industry always use a combination of full flow & bypass oil filters - in the OEM design. Adding one on to an engine that gets used in other types of applications as well is perfectly legit and has great benefit for long haul use.
We know the psi doesn't change thanks to 69, but our sumps don't carry near enough oil to hold tbn for long haul use. Those bypass setups can go many many miles, even with tbn boosters the oil will be clean to make the juice worth the squeeze. With acid build up in a small sump of 7 quarts, it makes more sense financial and other just to change the oil more often like at 10k miles.
ha, that's funny is a tragic type of way. Knock it off guys.
AFMoulton
Nuevo Mexico
Another perspective on lifter failures. Interesting what he says about the 6.4s.....
Well this is reassuring LoL. Thanks Corey. Glad we use good oil and change it often. But this kinda **** makes me want that 6.6 Push Rod V8 in the new Chevy.
2018 Ram 2500 6.4L 4x4
Amsoil SS 0W-40
AFMoulton
Nuevo Mexico
Amsoil SS 0W-40
Travis8352
Houghton michigan
That moment when you had 8 quarts of schaeffers 9000 5w20 ready to go for your oil change this weekend and somehow 5 quarts were stolen from me. First time buying fancy expensive oil and this happens just my luck. Now who did it? Lol
Another good lifter video
good info on mopar part number stamp, but I'm pretty sure we have oem lifters and they are ticking? Funny about some of the execution of the designs? I like this video Corey good find, you gonna try those lifters, which ones? Stock non mds hellcat lifters, so fca had the answer all along but just didnt use it?
When Corey finds a video they are must watch tv.
Wait a cotton pick'n minute here, are you telling me a dude that works for fca and on hemi's every single day is telling you there is a problem with the hemi? Nah. To many people on the forum says there isn't, he MUST be mistaken.
