Used 2013 Ram 1500 4x4 SL
MarshRam
2014 SLT 4x4, 2012 ST
Put "2014 dodge ram owners manual" in google search engine and you should be able to find a pdf version to download.
T
Tom Przestwor
1845 Lindell Road, Las Vegas, NV 89146
4.7L
MarshRam, I've done that and a 754 page manual come up. I printed the sections I thought would help me, but I'm looking for the list of items that came stock with this model. I'm going to try CARFAX next. I was just curious to see if anyone knew anything about a stock 2013 Ram 1500 4x4 SL. Thanks for your help though.
MADDOG
Out Exploring Arizona
There were three or four head units available so it's kind of hard to determine exactly what you have without more info.
Take a look at the head unit. There should be three small characters somewhere on the faceplate. Post that up.
Or, take a pic of the head unit and post that up.
MADDOG
That appears to be the Ram 3.0" RA1 head unit.
You can get the manual and download it on Google by using the term:
2013 Ram RA1 3.0 radio manual
Or send me a PM here with your email address and I can send it to you.
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Yep, Ra1.
No Bluetooth or phone capabilities.
Your can direct swap an Ra2 from a 13-17 ram for basic bt functions and ability to add the Mopar Backup Camera to display on it (or go straight to the 8.4 radio using a custom harness) ...
then swap in the steering wheel with phone/BT & VR buttons and rear Audio buttons (or add them to your existing wheel). If your goal is full phone support, you would also need to add the RearView mirror with mics and it's harness that goes up the front passenger side 'A' pillar.
Some links...
This will help you with PNs...
- 2013-2016 RA2/VP2-NA Radio Notes
If you need to add the manual Mirror w/mics for the Ra2 and up for phone connectivity, this will help also...
DIY: 2013-2016 RearView Mirror Upgrade & Harness install
- https://r.tapatalk.com/shareLink?ur...&share_tid=87837&share_fid=17770&share_type=t
DIY OEM Backup Camera thread (see post 10)
- http://www.ramforum.com/threads/installing-oem-backup-cam.53505/page-101#post-1401973
You can also do a conversion and upgrade to the 8.4 Ra3 or ra4/Nav...
- DIY: 2013+ RA3/RA4 8.4" Radio Conversion Upgrade
M² Mods.
