USMC1188
- Feb 14, 2012
- 1,905
- 271
- Location
- SW Ohio
- None
- Truckless...
Jacked the truck up today to check my front end parts and maybe narrow down the noise.
On a solid front axle, a give away sign of a bad ball joint is a 12-6 movement of the wheel. I had none at all, the wheel wouldn't budge.
I also checked the tie rod ends for movement and play at all, and had none.
The only front end part left is the axle u-joints, so my front drivers side u-joint sounds like it will be needing replacing... joy...
