Anyone good with AutoCAD?
kg93
kg93
AZ
Here you go... an updated version that ties in the cab basket to the rest of the cage.
You could have the shop weld up some tabs to the front to mount your lights. Wouldn't be hard to add them to the front.
almost perfect! One more version should do it! :roflsquared: sorry :happy107:
Just add the measurements for me please!
EagleChief
Oklahoma
2014 Big Horn
I didn't do the measurements just in case there was something else to change first. I'll make up a drawing that has the measurements on it. It'll have to be after the weekend, though. I'll get you some measurements on Monday.
kg93
kg93
AZ
its good enough, the rest i can just explain to my guy
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
The guys/gals on this forum are awesome. It never ceases to amaze me how helpful just about everyone on this site is. Willing to help total strangers out like this. It is impressive. Ask just about any question and someone will try to help you if they can.
EagleChief
Oklahoma
2014 Big Horn
Just realized I forgot to turn the crossbars back on on the basket over the cab. I had them "hidden" to work on some other parts.
kg93
kg93
AZ
i didnt even notice at first!
R/T_Fire
Pleasant Grove
Just one other thing you need to do.... teach me solidworks lol [emoji6]
kg93
kg93
AZ
Since you'll be going back into mind actually just doing one last thing? Pull the top rail back an inch or two and put a light cage on it, feel free to do your own design. It just needs to fit 4 9" round lights. Similar to the way the smittybuilt rack is but it doesnt have to look just like that 5adb5958f4927500e423ad49d9053fa7.png
Sent from my LG-H900 using Tapatalk
huntergreen
Marine Corps Navy Badge
nice designs.
Dmopar74
Not sure your aware but the bed rails on rams get skinnier as they go back. The bed on my 6'4" box looses 3.5" width from front to back
baum
savage, mn
2015 Laramie
i cant tell from your pic, but did you have those 4 rails from the front to the back solid the full length or are they "cut" at each intersection?
reason i ask is it would be stronger to keep them solid and cut the members that cross them.
do you have an fea program to see how much the over hung part can safely hold?
EagleChief
Oklahoma
2014 Big Horn
Here is a rough drawing with some dimensions on it. I adjusted the cab basket rail back 2" to allow for your light bar. I'll let your fab guys come up with a design for the lights. I'm pretty sure this should give them enough to go off of. Good luck with it. You'll have to show us some pictures when you get it built.
FYI... I didn't know what type of material you are going to use. I just picked some basic tubing to use in SolidWorks. You can have your shop use whatever they deem necessary. They will probably make some changes as necessary to help with rigidity and support. And, just to be safe (because you never know in today's society), I'm not liable for any damages after this point. ;) I'm not an engineer, so don't hold that against me. :D
kg93
kg93
AZ
Sweet thanks man, more then enough to go off of. I owe you one haha.
Lmao I like your disclaimer
EagleChief
Oklahoma
2014 Big Horn
You ever get your shop to build this? Show it off, if you did. :D
EagleChief
Oklahoma
2014 Big Horn
Just checking in to see if you ever got this built.
