Aux Reverse Lighting - Let's see your setup!
wsutard1
Woodinville, WA
HEMI 5.7 eTorque
Yea, mine are on a switch. Not exactly flush with my bumper though.
Not that it matters, but I don't get the whole "don't want to see them".. What's different between seeing those and the giant factory housing?
IMO
IMO, cause they are ******* UGLY.
I also like the idea of being able to use them and not being a **** to others around me. Cause I'm cool like that.
Stealth is key for me.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
7" floods :)
IMO
Mine are floods as well and mounted in nearly the same location. Your light output is very good. What brand/price are those?
AustinB
Banned
San Diego, Left Coast
I swapped my halogen reverse bulbs for led.. It's much better, don't need any aux reverse lights. My lights are for working in the dark (ie field dressing a deer, setting up a tent, fishing, tailgaters, etc..)
Both setups have a good purpose. The "stealth way" would be perfect for if you dropped your groceries, and a can rolled under the truck.
IMO
dereck56
Are u guys running the cree led lights? I read a lot of review about condensation getting inside the lens, or not working. Has this happened to anyone?
Sent from my SAMSUNG-SM-G928A using Tapatalk
AustinB
Banned
Cree is a bulb, like phillips. 99% say cree over phillips...
If your buyimg a bar and it just says "cree" on it... That means it is a no-name china brand, and it should get foggy, blow up, and then kill a poor bunny rabbit.
Do you want to kill bunnies?
IMO
wsutard1
Woodinville, WA
HEMI 5.7 eTorque
IMO
Said no one else, ever. ;)
Aww guys, you are going to make me blush.
I probably only need the LED backup bulbs like AB mentioned. Be truly, seeing lights drop down below the bumper is just plain fugly.
Back in '97 I had a Cherokee with fog lights mounted beneath the front bumper. I was off-roading in Fairbanks, Alaska and broke through some ice and got stuck in the mud. 4 hours later when I was able to extract my Jeep I noticed that the lights were hanging by the wires as the ice/weight of the jeep snapped the mounting brackets off.
True story.
dereck56
So what's the name of the led pods your running?
sbarron
Wasilla, Alaska
True story.
That's what you get for using Chinese lights. Had they been Rigids, not only would they have not broken, they would have vaporized the ice and mud in front of your Jeep allowing you to simply drive out.
Rzrman328
The treeline
Nilight
The same exact set on my truck I also have on an atv that I use frequently for night riding.
No issues.
Galion
Edmonton, AB
Nilight
No issues.
X2 for Nilight, my rear flush mounts are nilight's and I have a set of flood pods behind my grill from them. Very bright and zero issues.
reek
Sacramento
I have a set of made in china with what inevitable uses fake CREE bulbs in a sweat shop produced lead based painted aluminum housing, mounted into cut outs in my bumper. in an ideal world, I'd have Rigids. instead I just live in envy and have a second set of the same lights in a box in my garage waiting to be installed when my current set craps out. Funny thing, the pods in my wife's truck front bumper, Rigids.... not sure how she pulled that jedi mind trick on me.
Arturo Rojas
