blackout11
- May 23, 2011
- 4,000
- 453
- alpharetts GA
- 2011 R/T
- hemi 5.7
Ok ive gotten alot of pm's about my headlights i will give you the pros and cons about 2 different brands of projectors.
But bottom line if you want a really good set of headlights the jj at retro is the best bet.
Ok first we will discuss recon
Price -549-560
If you plan on installing hid's in these you will have to drill out the bulb housing the led's in the outside strip are dull and the led (halo rings) are dull and not very bright. You can upgrade to ccfl but will cost more.
Spyder
Price -297-300
Look at them dont they look just like the recons but at a huge price difference.
Do not need to drill out housing to put in a hid bulb. Same as above the leds are dull and can be upgraded to ccfl foir more money.
So the stock h-1 bulb that come stock in both lights are even worse the stock bulbs on the quad headlights. But the spyder are better because of the price difference and quality.
Reason i got mine was simple wanted a different look and i planed on taking them apart i added much better ccfl rings and way brighter led bulbs and also painted mine inside to match the truck.
But i wanted to get this out there so you know the price difference and the hassle you have to go through to put an hid bulb in the recons.
This is what you have to do to get hid's im recons
before
after drilling
So hopefully this helps but like i said if you want a really good set of headlights talk to JJ
Price -549-560
Spyder
Price -297-300
before
after drilling
