nickpohlaandp
- Jul 15, 2016
- 741
- 241
- Lake Charles, LA
- 2014
- 5.7 Hemi
So today I finally got around to installing a few goodies, and getting rid of some crap from my truck. I removed the factory clutch fan and factory electric fan, as well as the fan shroud. In place of all that I installed an electric fan from a 2011 Ram V6 and while I was at it, I threw in a 180 degree T-stat. I also have already installed my Billet Technologies oil catch can and there's a pic here of that. Additionally I got my VaraRam intake install pictures in here. Time for some pictures and a few notes as I go.
Here's a picture of the crap that I got rid of.
Removing all of that was fairly easy. The clutch fan came off by putting a #2 screwdriver through one of the holes in the water pump pulley and using a large crescent wrench to break torque (it is reverse thread). Once the clutch fan was removed, there's two bolts on the top of the shroud, one on each side, securing the shroud and the existing electric fan. Remove the bolts, push on the lock-tabs at the top of the "ears on either side of the shroud, and lift out the shroud, clutch fan, and electric fan all together.
I didn't take a picture of the fan before I installed it, but the install is very straight forward. Here is a link to the fan I used.
2010 DODGE RAM 1500 PICKUP 3.7L V6 Radiator Fan Assembly | RockAuto
I used the TYC 622320 and it fit perfectly. There were a few electrical modifications required though. First, I removed the temp sensor from the new fan, modified the little plastic piece it's on, and reinstalled it to block the hole it left in the shroud.
Once I got that taken care of, it was time to address the electrical connections. The stock connector has a nice little clip that holds the body mounted side of the connector to the shroud. I broke it off of the shroud, trimmed it down, and bolted it on with the new fan.
I cut the connector off of the old electrical fan, cut the connector off of the new fan, and spliced the old connector to the new fan. I used crimp connectors with heat shrink weather guard, and as a double measure I used some additional heat shrink over that. Never have to worry about water getting in. Then I drilled a small hole for a zip tie to secure the fan harness so it wasn't flapping around in the wind.
Next was the thermostat installation. As a general rule of thumb, I always drill a 1/16 hole in my thermostats so there is always a tiny bit of flow even when the thermostat is closed, and it does wonders for burping the system. If you do this, make sure you deburr the hole after you drill it. Also, 1/16 is plenty big, no need to do any larger.
Install the thermostat with the burp/bleed hole on the top side for obvious reasons.
After this, I reinstalled the radiator hose and started filling the system. All was looking good and once I had it full of fluid I started the truck. As the system built up some heat I noticed that the radiator hose kindof crept toward one of the braces on the new electric fan. At first I decided to use my angle grinder and just trim it down some, giving it a nice radius. As more heat soaked in, it was still too close for comfort, so I decided to use the 'ol zip tie trick and secure it so there wouldn't be any rubbing, leading to a punctured hose down the road.
Here you can see where I radiused the brace on the fan, as well as the zip ties.
Now it was time to reinstall the VaraRam intake and take a few pics.
With the stock airbox gone, there's TONS of room to easily get at the oil catch can. This is also the best picture I have of the V6 fan installed.
And dang, does that VaraRam intake look good.
After I was done up front, I went around back and threw on the Hellwig rear sway bar. No pictures of this one, sorry. It couldn't have been easier. 4 bolts, 2 nuts, remove old one, install new one. Done.
I took the truck out for a drive and everything worked great. I didn't have time to really go test out how it felt with the new sway bar, but I'm sure it'll be nice to have. The sock one was so lightweight they almost could've saved themselves the time of even putting one on. The Hellwig is a hefty piece. I'm looking forward to towing my camper with it. That's where I'm sure I'll notice the difference. I guess at this point I just need to get with Sean to have my tune revised for the new T-stat.
