Synthetic Oil
Oil of Choice
  • Castrol Syntec/Edge
    Votes: 254 8.4%
  • Royal Purple
    Votes: 344 11.4%
  • AMSOil
    Votes: 428 14.2%
  • Valvoline Synpower
    Votes: 174 5.8%
  • Mobil 1
    Votes: 1,077 35.7%
  • Other
    Votes: 737 24.5%
  • Total voters
    3,014
Nutshell
The 2013 + filter may be different.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Yup the filter I put up is the one for pre 2013 4th gen Hemi.
Danno
Mid Atlantic
2016 Power Wagon
If you look in the filters you can see a coil spring, most have coil springs If you buy quality. I have yet to see a mopar MO899 without a coil spring.
R.L.K.
Bristol , Tn.
The Mopar and RP 10-48 Filters I've used all have had the coil springs ...
U&A
Michigan
2016 3500 SRW
6.4 HEMI
Just want to add my "Lifter Knock" experiance and what the dealer said today during a free oil change. I explained it in laymins terms for them and at first they had no idea what i was talking about. Then all the suddin they say " its normal, don't worry about it". I still got it noted on my record.
Its funny when somthing that isnt supposed to happen, happens enough times and nothing its done about it, society starts to accept it as "its normal".
Lol
"Normal" it is, but "ok" is a different story.
R.L.K.
Bristol , Tn.
@Hemi395 , thanks for that post , I've seen that before , can't remember if it was here or there ?
The best part about that post by P Bell , is the discussion it created below . If you have the time read 50+ post below the one you posted , pretty good info there .
RodRam
Ga.
Hey guys what oil temps are you getting unloaded at hwy speeds, my amsoil 5-20 is getting up to 225 most times sets on 222 is this normal seems i noticed lower oil temps with 5-30
Hemi395
Cape Cod MA
I've seen my Amsoil 5w30 as high at 217 but no higher than that. Of course the hottest it's been here is the high 70s...
R.L.K.
Bristol , Tn.
Highway speeds with an OAT of 84°f just today after about 50 miles @ 70 mph my highest temp was 212 . That's actually the highest I've ever seen my oil temp.
I haven't paid too much attention to oil temps , only about the last year or so , but today's 212° is the highest I remember seeing .
I don't believe my 5W-30 ever got above 210
Nutshell
Depends on what thermostat you have. I'm stock and see 215-222 unloaded. 224-234 when towing. Currently on 5w30 QSUD.
R.L.K.
Bristol , Tn.
I wish I'd see 215 -220 ° out of my oil , I'm always concerned my oil isn't getting hot enough to burn off condensation .
I wouldn't think 225 or a little higher would be an issue .
I believe the Flashpoint for most automotive engine oils are 400+° f , I would think they wouldn't loose lubricity characteristics till 275+ or carbon up till high 300 s , just a guess on my part really , but I don't think 225 is an issue at all .
RodRam
Ga.
Mine is stock thermostat too today it was 92 degrees outside i was running 75-80 on interstate oil got as high as 226 coolant was 203-206, just wondering if this is normal operating ranges for the ram 5.7
Nutshell
I see that often. Here in Florida I can even see higher than that. I not concerned in the least
raven3
Central CA
5.7L Hemi RCSB Express
111F OAT here today, way above normal for June.
Only drove in town Rosedale highway@ 45 mph, 212F oil temp Max with 5w20 QSUD
If towing up 6% grade in summer here would prefer using 5w30 because oil temp will easily reach 230F
Too much for QSUD in my opinion.
According to 540rat blog the upper tlimit for QSUD is 260F where the oil looses lubricity.
raven3
Central CA
540rat is constant!y testing the lubricity of new engine oil formulations and posts the results.
The breakdown temperature is included in the test results.
According to 540ratblog.worldpress.com, QSUD 5w20 was tested at 230F with high lubricity factor of 121 ksi
Then tested again at 275F with a drop of 23% in lubricity down to 92 ksi.
According to the 540rat blog, this oil showed an initial decrease in lubricity at 260F.
This oil tests really high in lubricity, one of the best on the market, this is the main reason for using it in my engine.
If the the 5w20 goes over 230F would then elect to go with QSUD 5w30.
This would only happen if towing something like an 18 ft boat & trailer up a 6% grade during the summer.
Have not noticed the temperature > 230F, even on the 7 mile 6% uphill grade frequency driven about three times\ week.
My normal operating temperature is 213-215F on flat ground.
bbramer0820
