P1524 "Oil pressure out of range"
Daw14
South Florida
I forget where I ordered from, it was remanufactered and was less money than I thought, around 200$
The “credits” the tuner buys is where the majority of the cost comes from.
I got engine and transmission tunes and it was around 1200$ plus some $ I gave to the tuner for his time, I’m not sure he does it for a living, met him through my mechanic.
I can barely figure out my phone when it updates, don’t own a laptop/ computer, I would never attempt to do it myself.
I will look for my receipt, keep most of truck stuff at my MIL’s, to get the company I ordered the cpu from.
I’m about the same speed when it comes to technology.
My wife has to pretty much do most things , it takes some persuasion, however , shiny things a few times a year seems to work.
EdGs
FL
Not a problem if you can't find it. It's gonna be down the road a bit before I can even think about the upgrade anyway.
Bubbajones
Hemi-5.7
just took a drive. At idle while warm it was around 30-33. When driving at 2k rpm it went o 38. It never went below 30.
That oil pressure is low for 2k rpm. It should be around 53psi. Check your oil first to make sure you have enough and it isn’t burnt. If that is ok, Change your oil pressure sensor. If that doesn’t work, change your oil filter. If all that is good and you know you have the correct viscosity, your oil pump is going out or your engine bearings could be wearing.
ChloeBrooks
