Automatic Door Locks Will Unlock, but Won't Lock
BIGRed333
Houston, TX
Cummins Turbo Diesel 6.7
Howdy,
2013 Ram 2500 Laramie
Remote Key Enter
Keyless Enter-N-Go
Push button start
Issue:
Automatic door locks will all unlock, but only the driver door and the tailgate will lock.
I press unlock on either the key fob, the exterior keyless enter-n-go (driver and passenger), or on the interior switches (driver & passenger) and all doors (driver, passenger, two rear, and tailgate) will all unlock. Peachy.
I press lock on either the key fob, the exterior keyless enter-n-go (driver and passenger), or on the interior switches (driver and passenger) and only the driver and tailgate will lock. Grrrrr.
At first, it was intermittent. Maybe the passenger doors would lock, maybe they wouldn't. Then it went away for a little while. Then it came back it is constant, the three passenger doors won't lock.
I didn't touch any settings, but I went through the UConnect menus to see if somehow a setting did get changed. I haven't found one.
The closest thing I found on the forums was this:
http://www.ramforum.com/f76/how_program_auto_door_locks_your_ram-35396/
But that didn't do anything for me.
Any ideas?
If it was just 1 door, I'd say an actuator problem. Couple that with the fact that they will unlock, I'm thinking not an actuator problem.
Thanks in advance,
Carrie
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
B
BIGRed333
Houston, TX
Awesome! Thanks for that Hootbro! I'll see what I can find out and then post a reply.
B
BIGRed333
Houston, TX
Haha woops!
Jeremyf80
Cummins6.7
Did anyone figure this out? Mine is doing the same thing.
B
BIGRed333
Houston, TX
I dropped my truck off at the dealership last week. They replaced a door latch in the driver side passenger door. The doors locked a few times, but then stopped again. Truck is back in the shop today. Will report back when fixed for sure.
- Carrie
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Haha woops!
- Carrie
This seems to be common some reason. Mine failed a couple weeks ago I am replacing the actuator. By it I mean the drivers side rear seems to be common one that stops working.
B
BIGRed333
Houston, TX
I'm not sure. Below is my first invoice which did NOT fix the problem:
"Right front and both rear doors wont lock (ELECTRICAL CONCERN) VERIFIED CUSTOMER CONCERN. VERIFIED INTEGRITY OF CONNECTORS I600, I750, I700 BY WIGGLE TESTING AND MONITORING DOOR AJAR NOFICATIONS IN EVIC FOR CIRCUITSS P910, G76, AND G77. DISCONNECTED I750 AT RIGHT REAR DOOR. TESTED PIN 2 CIRCUIT P292 FOR POWER WHEN LOCK/UNLOCK ACTUATED; 12.3V PRESENT. REMOVED RIGHT REAR DOOR TRIM PANEL AND DISCONENCTED RIGHT REAR DOOR LATCH CONNECTOR. TESTED PIN 1 CIRCUIT 292 FOR POWER DURING LOCK/UNLOCK ACTUATION; 12.3V PRESENT. UPON TESTING, FOUND RIGHT FRONT LOCK AND LEFT REAR LOCK STARTED WORKING WHEN COMMANDED. CONDITION PRESENT INDICATED INTERNAL SHORT IN RIGHT REAR DOOR LATCH. REMOVED RIGHT REAR WINDOW AND CARRIER PLATE. REPLACED RIGHT REAR DOOR LATCH. PARTIALLY REASSEMBLED. TESTED LOCK/UNLOCK FUNCTIONS; ALL DOORS RESPONDING TO COMMANDS. REASSEMBLED VEHICLE. REPAIR VERIFIED."
I tested it at the dealership before I left, all doors locked. Doors locked 5 more times after I left, but the 6th time didn't. Couldn't get them to lock again. It's back at the dealer now.
One thing that I noticed is that when the ambient temperature was low, it was intermittent on when the doors would lock. I thought maybe a wire is cut/crimped because when the temp is low, humidity is lower, maybe it's easier for the current to pass through a damaged wire. But I honestly have no idea what I'm talking about.
I'll post the results when I get 'em.
RamCares
Michigan
n/a
n/a
- Carrie
If you end up needing further assistance, let me know. Thanks - Kevin T, Social Connect Team
Jeremyf80
Cummins6.7
I'm dropping mine off at the dealer today, and it started working again, but then I tried the passenger side, and it unlocked as soon as I touched the chrome on the handle. Now it's not working again.
B
BIGRed333
Houston, TX
I dropped my truck off Monday morning (today is Thursday). I received a call Tuesday night to let me know they are still working on it and haven't figured it out yet. No call Wednesday. I expect a call today.
RamCares
Michigan
n/a
n/a
Thanks for the follow-up. If you would like me to look into this further, please DM me your VIN, servicing dealer, service advisor and your contact number. – Kevin T, Social Connect Team
dwall
I dont have anything to add, but I have a 2014 Ram 2500 crew cab. The problem is, when I am in the drivers seat, if I push the door lock button....the doors do not lock. If I am in the passenger seat and push the door lock button...the doors lock. From the drivers seat, the only way to lock the doors is to put the truck in drive, and drive. Is this normal? Ideas on a fix?
RamCares
Michigan
n/a
n/a
Hi dwall--I don't think that's normal! If you're interested in having your dealership check the locks out, I'm happy to help set up an appointment. Just PM your VIN and contact info.
Kori
Ram Social Care Specialist
B
BIGRed333
Houston, TX
Does it also lock from the key fob?
If so, sounds like you've probably got a problem with just the button mechanism on your driver door. But I am by no means any sort of expert.
Jeremyf80
Cummins6.7
Just got my truck back, they replaced the body control module. It works so far.
B
BIGRed333
Houston, TX
Got my truck back today too. Monday to Friday. They replaced the door latch again. We'll see if it holds.
"Right front right rear and left rear door locks inop see his
tory (ELECTRICAL)
VERIFIED CUSTOMER CONCERN. NO DTCS. NO APPLICABLE TSBS.
REVIEWED WIRING DIAGRAM, TESTED POWER CIRCUIT P777 AT DRIVER
PASSENGER AND REAR DOORS, BATTERY VOLTAGE PRESENT WHEN
ACTUATED. TESTED POWER CIRCUIT P292 ON DRIVER, PASSENGER
AND REAR DOORS, BATTERY VOLTAGE PRESENT WHEN ACTUATED.
TESTED GROUND INTEGRITY FOR Z905 AT DRIVER DOOR LATCH PIN 4;
.3 OHMS PRESENT. TESTED GROUND INTEGRITY FOR Z909 RR DOOR
LATCH PIN 4; .3 OHMS PRESENT. TESTED GROUND INTEGRITY FOR
CIRCUIT Z906 LR DOOR LATCH PIN 4; .3 OHMS PRESENT. TESTED
GROUND INTEGRITY FOR Z909 PASSENGER DOOR LATCH PIN 4; .3
OHMS PRESENT. ALL GROUND CIRCUITS FROM FRONT AND REAR DOOR
LATCHES GOOD. REMOVED RR DOOR LATCH FROM CIRCUIT; NO
CHANGE IN CONDITION. RECONNECTED. REMOVED LR DOOR LATCH FROM
CIRCUIT; REMAINING LOCKS NOW OPERATE. DUE TO CONDITIONS
RESENT, RECOMMENDING REPLACEMENT OF LR DOOR LATCH AND
HOLD VEHICLE 1 ADDITIONAL DAY TO RETEST SYSTEM FOR FURTHER
ISSUES.
PART ETA 06/30 LR DOOR LATCH DALLAS
REPLACED LEFT REAR DOOR LATCH. TESTED LOCK SYSTEM; ALL LOCKS
OPERATOINAL AT THIS TIME USING FOB COMMANDS, DRIVER DOOR
SWITCH AND PASSENGER DOOR SWITCH. WILL RETEST 07/01 TO
VERIFY REPAIRS.
07/01 10:15AM; TESTED LOCK AND UNLOCK FUNCTIONS FOR ALL DOOR
USING KEYLESS GO ON DRIVER AND PASSENGER SIDE, RKE FOB,
PASSENGER SWITCH COMMANDS AND DRIVER SWITCH COMMANDS. ALL
DOORS LOCK AND UNLOCK NORMALLY AT THIS TIME.
B
BIGRed333
Houston, TX
My locks stopped working again. The left rear door latch is clearly not the root cause if it has now been replaced twice and doesn't solve the problem. Guess I am headed back to the shop on Tuesday. Ugh. This'll be the 4th time going to the shop for the same issue.
