Cabin Air Filter Mod
Repsol69
Do the 17's already have this done form the factory??
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
At least the door is there, I'm not sure if the filter itself is installed. It began with later 2016 production.
Superman2000
Did this mod today. PITA. Could not get the door to snap in place on the left side for nothing. No matter how hard I pushed or bent the tab inward. Finally said the hell with it and duck taped it
Ed loves guns
Haha I did the same thing and it lasted 12 hours before my OCD took over. I could not figure out why it would not snap on there. But if you take a smallish screw driver or something similar and stick it back next to the left tab, after you have the right tab snapped on, you can push the left tab onto the post and it will snap on there. Think the opposite of prying it off. I was angry with my self for how easy that was and not figuring it out in the first place.
RamblinRod
Crawford, CO
2016 Ram 2500 CC LB 4x4
Just completed this while I had the glove boxes out for 8.4/4-7 speed fan conversion. Guess I was lucky, the door popped right on. I'm surprised no one has mentioned that you have to scrunch the filter up some to get it in due to limited space on the right hand side. Glad I put in the rubber bordered K&N instead of a paper filter. Did noticeably cut air flow.
HEMI_Finn
U.S. ARMY Veteran
Army
N.E. Ohio
Hurricane 3.0 HO
Just ordered the door and filter. For less than $30 this is a great mod!
Sent from my SM-G900V using Tapatalk
guarj17
Long Island, NY
Just saw quietpeen's pics, going to have to re-look under there. What the hell is up with the retractor thing on the glove box. Thing is annoying.
Hipps2000
2013 Ram 1500 Bighorn
Hemi 5.7l
My 2017 has the door and filter installed...
It's about time RAM finally stepped up to the plate....could never understand why everything was there but couldn't add a $5 part so the cab wouldn't be a dust pit.... Also Genos Garage sells a CAB filter kit that bolts on under wipers and hood and covers the vents where all in coming air enters cab. I have purchased a few years ago and buy replaceable filters and change them yearly...it really helps along with the blower motor filter. My cab stays nice and clean and low dust on dash. Really helps with pollen too! Highly recommend them....they were designed for semi trucks.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Can you link to that intake kit for the hood?
Mattyyo
Houston
?But do you think there is a reason why they skipped out on the air filter?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Can you post a picture of what it looks like with the hood closed?
https://www.genosgarage.com/product/cff-dg-19009k/cab-filters
danmp
Québec city, Canada
Do you know if it's possible to order the geno's garage kit, in Canada ?
I was ready to order a kit and a replacement filter kit for 70$ and then saw a 75 $ shipping quote.
So in CAD it's about 200$ .that's crazy
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Do not know about GENOs but also try E Bay Canada as they have the kits on E Bat US.. 75$ shipping Damnn do they provide lube while screwing you? :O Frigging crazy
hers a page I found, but If Geno ships to Canada he is well liked here
http://www.ebay.ca/sch/i.html?_from...it.TRS0&_nkw=ram+cabin+airfilter+kit&_sacat=0
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Anyone have the part number for tge cheapest filter? That's what i used last time and was happy. I'm thinking​ it cost me about 8 dollars
Sent from my SM-T819Y using Tapatalk
E Bay that is where I got mine for my HHR, And if I remember the CAF is from a Avenger, But do not know the number
Limeybastard
Shady Hills, Rednecksville Boro, Florida.
barr0208
winnipeg manitoba
2019 ram 1500 sport long bed
5.7 3.92 4x4 ruby red
go to your chrysler dealer get the dodge avenger cabin door and hit your local parts store and get the filter it will be cheaper than $70 dollars cana:roflsquared:dian
DiselRam3500-Fl
