I will use one of the purpose built ramps from discount ramps or similar
https://www.discountramps.com/motorcycle_ramps/p/MF-12038/
that is designed for loading and unloading bikes by one person
so getting it in and out wont be a problem and my main question was to those that have done it
as I was curious what I can expect from the handling
Those are really nice ramps. I suggest walking the bike up the ramp (you can have it running and use the clutch to feather it up while you walk on the clutch side).
Make sure you strap the ramp to your bumper/hitch so it doesn't move as you load/unload. This is one of the biggest mistakes, that people forget, that causes all the accidents. The ramp will want to slide off the lip of the tailgate as weight transfers.
During your trip, be sure to strap that ramp down well so it doesn't make contact with your bike as you make the trip.
I know you already have the chock, this is for the benefit of anyone else who searches this thread in the future:
I am not a fan of leaving a bike on the side stand during transport, the stand can fail (either push through the floor, or actually bend). I suggest getting a motorcycle chock stand (Harbor freight has 2, I have the more expensive one):
https://www.harborfreight.com/1800-lb-capacity-motorcycle-standwheel-chock-61670.html
Having a chock prevents you from having to over compress the forks. You don't have to attach the chock to the bed of the truck, just be sure to strap the bike down once on the chock. Also, be sure to strap the rear to prevent it walking left or right. You only need it to put a little tension each way so it prevents side movement.
You will likely (as you expected with the heavy duty tailgate straps) have the rear wheel on the tailgate. This is fine, but some people like to place heavy plywood to spread the load back onto the bed (I'm not sure it is necessary).
Once you have it properly loaded, you will feel that you have added weight in the bed, but other than that, it will drive normally.
I have aftermarket projector light housings with HIDs, which I have aimed right below the average drives eyes. When I have a heavy trailer (lots of tongue weight) or extra weight in the bed, my headlights point up to where they annoy on coming traffic. If the trip is long, and you have the same issue, it may be beneficial to adjust the lights fully loaded for the trip.
