03 1500 p0601 problems
Is it the pcm or a sensor or wiring
  • Wiring and sensor issue
    Votes: 0 0.0%
  • Total voters
doughboy95
Okc
3.7 v6
Hello i been trying to fix this P0601 it saus a memory checksum error and trying to make absolutely sure its the pcm cause not cheap. My check engine lights on and my seatbelt and airbag n which when i start it my airbag blinks one then stays solid whether i have it turned on or not. The sensor under my seat is cut and theres quiet a few connecters under the hood not connected its a 3.7 st base model not sure if there's dummy plugs or what like one under the tipmIMG_20210402_185158.jpg IMG_20210402_185228.jpg
https://www.obd-codes.com/p0601
Causes: A code P0601 in most cases means the PCM has gone bad. This is possibly due to a short-circuit inside the PCM. Or, if you disconnect the wires/connector from the PCM while the battery is still connected, that may also cause this code.
Possible Solutions: With a P0601 OBD-II trouble code, the most common fix is to replace and reprogram the PCM. In a few cases the dealer may be able to reflash the PCM and get it working.
doughboy95
doughboy95
Okc
3.7 v6
Ik ive read all that but theres no way possible that its something else and person who i bought from wont give me a straight answer he changed the trans i wonder if he unplugged with battery on
doughboy95
doughboy95
Okc
3.7 v6
Its starting to be undrivable like when i hit the gas its sluggish n the rpms drop if im turning n also going straight from a dead stop like its running out of gas but i got half a tank
