My '15 had a squeak in the brakes as well. Only heard at very slow speed, like a drive thru, etc.I changed the pads at 44K because the pads were squeaking and I couldn't stand it. Went with the Wagner OEX pads and the noise went away
You will need to be able to set up a dial gauge and check the run-out on both sides.Not to hijack this thread but does anyone know how to determine if a rotor is warped without any special tools? I recently picked up two Wagner E coated rotors on Amazon warehouse special for less than half price each. They do not appear to have been used. I just want to make sure they are not warped and true before I install them with Wagner OEx pads. I appreciate any advice.
^ this exactly. One possible cause that creates the pulsation that people associate as being "warped" is road debris that gets stuck to the rotor. As these high spots pass, the pads kind grab harder at that point and it, in a sense, reduces the forward momentum a bit more abruptly every time the spot passes.Rotors cannot really warp. Automotive experts note that rotors are metal discs that are cast under extreme heat conditions. It would take a similar application of heat by the braking system for rotors to bend, which is impossible. Other factors make rotors appear to be warped, so describing such rotors as “warped” is an easy way to explain the problem to vehicle owners.
For brakes to work correctly, brake pads must be applied squarely and evenly against the rotor. But friction can cause some brake pad materials to form residue on certain areas of the rotor, eventually contributing to uneven rotor surface levels. Some spots become thicker, while others may thin out.
Drivers’ own habits, including their braking tendencies, can contribute to uneven rotors. For example, riding the brakes for prolonged periods of time can cause hot brake pads to “paint” the rotors. So constant braking should be avoided.
Great write up. It makes sense. I didnt seat the pads when I did them a year ago. I didn't know I had to. Maybe I'll try scuffing the rotor with sand paper to see if I can save them. Or save the headache and just replace them with something new.Rotors do not warp in normal passenger vehicle operations. To "Warp" a rotor you would need to heat it to near red hot to do so. However there are 2 things that can effect the rotor run-out or feel.
1. Over torqueing rims and then getting high heat load in rotor. This can cause the rotor to slightly distort due to uneven expansion and contraction due to the over clamped force of the rim to the hub and effectively "squeezing" the rotor. Even though over torqueing of rim is extremely common at all tire shops, the likely hood of this happening is low (usually requires a heavy load and a long down hill off ramp, etc.).
- usually easily remedied but cracking lugs and resetting to correct torque. You don't even need to lift off the ground just back off lug and reset. (i have done this more than one before)
2. Most common "warp" rotor problem is actually imprint of pad material to rotor face. This is very common as very few shops actually fully seat new pads when installed. There is a lot of back and forth about seating pads. It used to be required with old pad technology and materials. Most think its not required these days. I as well as Power Stop would disagree (you void pad /rotor warrant if you fail to follow their pad seating procedure). The heat cycling of new pads helps to "cure" the material and minimize "imprinting" on the rotor face. You can also over heat a lesser pad compound and cause it to imprint as well, much less likely.
Check out Power Stop seating process. It works very well. Also FYI, using this process when you start to feel a pulse in brakes can in some cases clear the imprint from the rotor face before it starts to cause wear anomalies in the rotor face and make pulse "permanent".
As for reusing old rotors:
1. front rotors I would suggest replacing if the vehicle has low miles (under 120K) and they have been in use for some time.
2. Any reuse of a rotor, if not taken to a shop and turned, should be scuffed with sand paper at a minimum to break down glaze on rotor face and allow for proper pad seating.
As for rear rotors, I rarely ever replace, nor turn as very few shops do it, and those that due tend to be M-F 8-4.
With respect to guide pins, rotor to hub/rim mounting faces.
- Mounting faces should be "clean" at least scrubbed with wire brush and a very light coat of anti-seize (it pays dividends when changing tires or future brake work)
- fyi I brush on anti-seize to back mounting face of rotor and carefully wipe off excess leaving just a thin film. I also do the same to the mounting face on the rim (verse actually applying to rim side mounting face of the rotor, less likelihood of contaminating pad area on rotor)
- pins clean (preferably replaced if any rust accumulates)and protective boots replaced unless they are in perfect shape (not usually the case)
-pins should get at least a coat of brake grease. I have actually changed to using anti-seize as I feel it decrease the likelihood of pins rusting / seizing in the bore. I do use a very small screw driver to insert some in to the bore before reinstalling pin, as well as giving the pins a coating as well.
Finally, to get brakes to operate well for a longer period and have less issues with pads hanging up in the carrier. I custom fit all my pads so they slide easily thru carrier and new tin clips (i.e. with just light pressure using pinky finger) before adding a small coat of brake grease. A file or careful use of a bench grinder will take care of the e-coat and material on pad ears.
- FYI, this process cleared up the issues with my Ford 150 front brakes which have a tendency to hang up in carrier regularly.
- this process also allows more room for heat expansion, further decreasing pads likeliness to hang up in carrier.
The correct terminology is lateral runout.in my opinion the surface is "warped"
Yes, correct. I noted that in my second post to this thread.The correct terminology is lateral runout.
The reason for I posted the whole explanation of rotor build up is someone is more likely to realize themselves that it due to their braking style that causing the problem if provided with the facts. If someone just states your brake problems are because your applying the brakes wrong, most people cop an attitude of "I brake just fine, been driving like this for years".
Just did the same and at the same mileage. Easily had 1/2 pad life but they were squealing and I drive alot so decided this was the best course of action. Getting the factory rotors off after 4 years was a PITA. New wagner E coated rotors and performance friction carbon metallic and shes quiet and stops much better. Only been a few hundred miles but so far so good.I changed the pads at 44K because the pads were squeaking and I couldn't stand it. Went with the Wagner OEX pads and the noise went away
This!!! (Above). Rotors don't warp. They get material transfer from the pads that create 'high spots'.Rotors cannot really warp. Automotive experts note that rotors are metal discs that are cast under extreme heat conditions. It would take a similar application of heat by the braking system for rotors to bend, which is impossible. Other factors make rotors appear to be warped, so describing such rotors as “warped” is an easy way to explain the problem to vehicle owners.
everytime you change the pads you should change the rotors , for even wearing, and then they need to be burnished in to prevent warping the rotors , as they say you can pay me now or pay me later, my thoughts
Try doing a break in process 1st to see if you can "clean" the rotor face..Great write up. It makes sense. I didnt seat the pads when I did them a year ago. I didn't know I had to. Maybe I'll try scuffing the rotor with sand paper to see if I can save them. Or save the headache and just replace them with something new.
Yes, most can be turned twice, but remember less rotor = less metal to dissipate heat from braking. In the old days the rotors where much thicker than today.I found places that charge 15.00 a rotor to turn. You usually can cut the rotor twice. Always get brand new pads to ensure an even fit. A machine shop usually has a lathe.
This has turned out to be a great thread with awesome input from everyone involved. Lets throw another scenario in here to keep it going. Lets say you decide to replace the front rotors and pads for even wear in....Do you replace the rear as well, even though they don't engage as much as the front?
