Free spin kit
crazy jerry
WY
i would like to see you try and break a 1555 joint or the stub shaft.
do you even know a single thing about the powerwagon mechanical components ?
4xdad
4xdad
Edmonton Alberta
2015 powerwagon
I have broken enough or seen it broken to know that nothing is indestructible I get your point the pws are tough my point is that everything can break so to spend money on tough parts is better than a tow say from the Yukon to Edmonton and even heavy duty stuff can be broken I run heavy equipment for a living I have seen and done all sorts of dumb stuff
4xdad
4xdad
Edmonton Alberta
2015 powerwagon
Larger tires heavy foot heavy load lockers = bang walking
4xdad
4xdad
Edmonton Alberta
2015 powerwagon
22hemi looks like he made his awesome truck about 3-400 lbs lighter I am making mine about 8-900 heavier by the time you figure in all the stuff I want to carry for
4xdad
4xdad
Edmonton Alberta
2015 powerwagon
I’m 60 years old and my wife has cops we are not hiking anywhere lol
Al Handy
Blairstown NJ
I am "old School" I like having freewheeling hubs. even though our trucks have the axle disconnect everything still rotates to some extent. Someone posted a link to the Ram-Man units. I do not recommend them; I went with them basically because I got lazy, and they were a real easy install. The good, yes Ford hub bearings and Warn hubs (an option). The bad, the OEM wheel sensor would on occasion not like the Ford Hub tone ring, and would cause the ABS to engage even on light braking. 2. the axle stub would move around, and IMHO cause a front vibration. And on the passenger side it would be extremely difficult to engage the hub when the axle stub moved outward towards the hub. 3. I removed them after 6 months and now I am out $1700!!! Real world fuel savings about 1/2 MPG.
