Tennis balls in suspension
Ellamay_the05v8
Ellamay_the05v8
4.7 Magnum v8
I haven't, but my guess would be get torn apart and spread out along the road.
yeah id imagine so at high speeds maybe, but i've seen it at the mud hole and trails a couple times so i was just curious.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
I thought this was a joke until I searched on it and came across a youtube video of some Indian guys stuffing tennis balls into a coil spring. So may things about that video make me wonder if these guys still have all their appendages...or are still breathing.
I guess it could increase the spring rate if you put enough of them inside the coil spring. But I would think it's only a short term solution.
crazykid1994
There was a video floating around for a bit about someone installing a football inside the coil spring as an air bag type insert.
Daw14
Just watched an episode of hot rod garage where they stuffed them in a Chevy with the big coils out back.
Administrator
I'm guessing the neighborhood dogs will take to liking your vehicle if you do stuff the suspension with tennis balls
