Is It Possible To Order From The Factory, A Standard Output Cummins Dually?
Goose55
Ajo, AZ
Cummins High Output 6.7L
Is It Possible To Order From The Factory, A Standard Output Cummins Dually--and preferably with the Aisin trans? I ask because I only want to haul a full sized, over the cab camper (a heavy one, with slide-outs), and don't need all that extra torque. More concerned with gaining a little fuel economy.
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
You can get the SO with the dually but to get the Aisin you have to step up to the HO.
Goose55
Goose55
Ajo, AZ
I guess the 68RFE would hold up OK with the SO Cummins hauling a very large camper. I just wished I could know when I might be able to factory build a 2023 dually.
tjfdesmo
AZ
My HO DRW would get 16 empty, sometimes a hair more, and a bit over 10 pulling a 17K gooseneck toy hauler at 65mph. What are you expecting?
Goose55
Goose55
Ajo, AZ
I'd like the SO with what is it the .355 gears? Hoping for 20 mpg highway. That would be what my old Toyota Tacoma 3.4l got, which would be phenomenal.
tron67j
Maryland
You are looking at 2x the weight and so much more wind resistance just for truck, then adding a giant wind catcher. Worrying about mpg is not something that is going to have a happy ending for you. Buy because it is the right truck for your purpose. Good luck.
Goose55
Goose55
Ajo, AZ
Thanks. I can always use a little luck.
06 Dodge
Forest Grove, Oregon
6.7L CTD
Don't recall seeing 3.55 IIRC they have 3.73 & 4.10 and maybe 4.44 but not 100% sure, a few years ago they had 3.42 but got rid of them in diesel trucks...
stevenP
northern Indiana
2022 2500 Longhorn
6.7L Cummins
At one time I had the HO DRW 3500, and a 2500 with the SO engine at the same time. Didnt really notice a difference in the MPG between the two as a driver. Basically it takes a certain amount of fuel to move an object around regardless. The aisin tranny definitely felt a little harsher on shifts while towing in tow haul mode, and the exhaust braking is more potent too. All of the HDs are are only offered with 3.73 gears standard. 4.10s are optional.
Scottly
Safety Harbor, FL
HO 6.7 Cummins
I owned a 2018 2500 with the SO/68RFE and I now own a 3500SRW with a HO/Aisin combo. The SO would get 17mpg around town(empty), and the HO gets 15mpg. The SO would get 24mpg highway(empty) and the HO gets.....15mpg highway (empty). The Aisin shifts like it's angry, but in tow/haul mode it shifts like a paddle-shifter F1 car...Hard, stays in gear at appropriate RPM, no mush, and power output in lower gears is increased(empty). The computer holds back full power on these units when empty and in lower gears (1&2) so you don't tear up the drive train from the torque. That's all i can offer you for a comparison.
Goose55
Goose55
Ajo, AZ
"The SO would get 24mpg highway(empty)"
That's great fuel economy for such a large vehcile! The SO would be all I need.
Goose55
Goose55
Ajo, AZ
Just wondering if anyone here might know. When will it be possible to custom order a 2023 3500 dually?
Scottly
Safety Harbor, FL
HO 6.7 Cummins
One more thing....My SO used about 1/2 of the DEF that my HO uses in the same trip, load(empty), weather, and roads/speeds. Since I got this HO, I keep a spare bottle of DEF in my cool room incase I don't have time to hit the store when it needs it. This thing uses a lot more DEF than the SO did.
Goose55
Goose55
Ajo, AZ
Yeah. I read the HO has a lower compression ratio than the OS and has to have more aggressive emissions. Just one more reason to go with the SO!
Joseph Godvin
Dundee, Michigan
The Allison automatic trans is used in Semi's and most City Transit Buses, Very Heavy Duty and Reliable, worked on them for 30 years. Just saying :)
Goose55
Goose55
Ajo, AZ
Will Ram be offering the Allison in the 3023 3500s?
