Installed AlphaRex Pro G2
HT RICHARDSON
La Mesa, CA
3.0L ecoDiesel
Those look nice!! I went with the old G2's. Now...I want the ones you got.
Do both of the white lights in your top picture stay on as DRL's? Is the light at the bottom the turn signal? If so, how bright is it?
With the two sets of LED bulbs, do you have any RFI or inference with your radio?
Highway
Ky
Nice i have those G2 pros also. Im thinking of going led also
B
brianw0048
EcoDiesel
The two white lights and the one underneath are the turn signals. The white ones turn amber.
I only have led in the high beams, I’ve got HID in the lows. No interference that I’ve noticed so far. I made all the necessary changes in alfaobd.
Cableman
Longisland
B
brianw0048
EcoDiesel
How do you like the 55w ballast with a 5k bulb color? Probably more like a 4500k color on the 55w ballast. Any yellow at all? Can you tell the difference in color between the led 6500kv fahrens?
I’ll check the HID vs LED color tonight. I wasn’t really worried about it…I don’t run the high beams all that much.
The HID doesn’t look yellow to me at all. I didn’t want any blue and am pretty happy with the 5k
Low beam against a brick wall
Cableman
Longisland
Sure does look white. You use the canbus setup or the none?
B
brianw0048
EcoDiesel
None on the HID but I’ve got everything changed with Alfa.
The LEDs came with an in-line resistor.
Cableman
Longisland
Yeah i have mine set to hid already from some others ive tried in the past, now after 2 years 1 of my leds are going out so figure I'd try 55w hid this time until i rip lens off and swap in new bowls if that ever happens.
Im reading some other harness may be needed due to amp draw from higher wattage ballast, but idk
B
brianw0048
EcoDiesel
The harness draws power from the battery but I never installed it. I’m drawing battery from the factory wiring.
When I first installed my HIDs, occasionally one wouldn’t come on. I’d turn the lights off and back on and it would fire.
They’ve been fine for the past year or two.
