How to change rambox lightbulb
acolic
Hamilton
Hi
I have not found a DIY how to change the lightbulb for the lights in the rambox.
One of the lights is not working. Is the whole assembly replaced or can I just change the lightbulb?
Thanks
Alex
SitKneelBend
St. Louis
3.6 Pentastar
Hi
Thanks
Alex
on my 2014 the bulbs are replaceable.
A
acolic
Hamilton
Changing the glove box light looks different than the rambox lights.
DA67Goatman
Ohio USA
There is a tab on the bottom of the clear lens, push/pull the tab towards the center of the lens and outwards to remove the lens. The bulb just pulls out after the lens is removed. I broke 3 out of 4 tabs when I changed to 194 LEDs so I ended up removing them and using a flush mount LED puck which was way better but a real PITA to install. They are great, but only after I tinted them cause they were way too bright.
