5.7 lifters
  1. G
    Hemi 5.7 running rough
    Engine was running well 275k. Going down the hwy engine light flashed with code misfire. Shut off to investigate and it would never turn back on to run the same again. Dash currently shows no codes, it idles and shakes rough. Will not rev past 4000. Can’t find any relatable videos online...
  2. S
    Regular valve train or lifter tick
    i just got a 2020 ram 1500 with the 5.7, i have looks absolutely everywhere for answers and they are all different, this Video was taken after an hour and a half drive still warm, any ideas to what it could be?
  3. S
    ALL 5.7's HAVE LIFTER ISSUES?
    Do all the 5.7L's have lifter issues? I have exhaust manifold / header noise that I've gone rounds with. Changed out the manifold for BBS shorties. They supplied sh!tty gaskets that failed. Replaced those. May have a couple bolts that have backed out, again. The racket of this motor...
  4. Q
    2022 Hemi 5.7L Lifter Tick
    All, I have a 2022 Big Horn, 5.7L with 53,200 miles. A week ago lifter on cylinders 5&7 where replaced by the powertrain warranty. One week after i started to hear that clicking noise again. I'm taking it back to the dealer again tomorrow. Any one had the same or similar issues you can provide...
  5. H
    Broken Cam Shaft Bolt
    I have a 2021 Ram 1500 with an odd issue around 30K miles. The Eco mode would cause a weird sound almost like a muffled Jake brake from an eighteen-wheeler, but only in Eco Mode. On the way into the dealership, the noise worsened and even stalled the vehicle twice in a less than 5-mile trip to...
  6. MarcoFuc
    Is it a lifter failure?
    So I have a tap/tick after camshaft and all lifters replacement along with a new oil pump “+10 psi above stock. And timing chain. But this tick only occurs when the oil temp is 180-200 degrees. And only at idle and soon as you add the slightest Rpm it disappears then returns once the rpm drops...
  7. MarcoFuc
    Lifter tick? Or exhaust tick?
    https://youtube.com/shorts/6jw79L3tuUg?feature= https://youtube.com/shorts/16Rdjj7SRnk?feature=share Here are two links to sounds I’m experiencing from my 2013 ram 1500 sport with 5.7 hemi. I am trying to get a better idea what it might be, I’m stuck between lifters or exhaust leak but I had...
  8. M
    Lifter Failure after non mds swap.
    Hello Fellas, Recently purchase a Texas Speed Performance OE Non MDS Cam Kit and got it swapped out at a local shop. 3 days after driving the truck, i got a rough idle and a cylinder 2 misfire code came up. Also one of the lifters got really noisy which im guessing is a failure because of the...
  9. 14Deebo
    OEM 5.7 HEMI MDS Camshaft and lifters
    Selling a stock MDS Camshaft and lifter set with trays from my 5.7 2014 Ram 1500. One of the lifters is bad, but I am not sure which one, so you'll have to check them to be sure. Cam and lifters have 53k miles on them and all appear to be in great condition (obviously other than the one bad...
Carbary
