ac blower fan
  1. nathanbmartin
    Fan Not Blowing 2017 1500
    First post here. Today my fan stopped working. Fuse is good. Relay reads the same as others using a multimeter (ohms). Replaced the blower motor ($175 at O’Reilly). Still doesn’t come on. I don’t want to start digging into the wiring to the TIPM. Looking for any suggestions (photos, videos, etc...
  2. J
    Auxiliary Pusher Fan for long Idle (K9 + AC)
    Hello All, From what I have read these trucks (2016 Ram 2500 5.7L Crew Long bed 4x4 SLT) have adequate cooling at idle. However I am planning on running this for extended periods which I have been told on a few different forums (non Ram) that is a bad idea. I have a Search and Rescue K9 that...
  3. SND2010
    Strange A/C phenomenom
    I just purchased a very clean 2010 SLT Crew Cab. I was driving it home from the dealer (125 miles) and I noticed that when I was stopped or moving slowly in traffic the volume of air blown through the A/C ducts seemed normal and cool. However when I was at highway speeds (75) the volume of air...
  4. Birdy Threadz
    Blower Issues
    I purchased my late grandpa's 2013 Ram 1500 Outdoorsman 32,000 miles on it, smells new (traded in my old Chevy) and I love it but there is an issue that I cannot figure out what is wrong with it. All summer the blower worked fine pumping the A/C no issue, and into the fall the heat blew fine...
  5. H
    AIR CONDITIONING ISSUE
    2009 Ram 1500 Laramie with AC issues. -All actuators I can get to immediately behind dash work properly. -Compressor and belts were replaced. - Thermostat was replaced. Here is what is happening after Compressor and Thermostat were replaced. Any idea what could be causing it? AC set on Lo...
  6. 2
    AC issues
    2007 Dodge Ram, 5.7 Hemi - not able to charge AC unit. Checked operation of blower, cleaned condensor, clutch engages on condensor. Using only standard single line with gauge to charge. Gauge goes up when compressor turned off (as it should I believe) but goes to zero when compressor on. ANy...
  7. J
    ac blower motor controller
    2016 Ram 1500 engine tick, fuel pump code causing check engine light, and 1/2 cup water dripping out of back side of muffler. Runs fine and gets good mileage, but does occasionally crank for a 20 second before starting if it has been setting for a couple days. Could it be something other than...
