Birdy Threadz
Chicago
V6
I purchased my late grandpa's 2013 Ram 1500 Outdoorsman 32,000 miles on it, smells new (traded in my old Chevy) and I love it but there is an issue that I cannot figure out what is wrong with it.
All summer the blower worked fine pumping the A/C no issue, and into the fall the heat blew fine. When it started getting colder the blower would just not work in the morning, but by the time I would go for lunch and the truck was heated up the blower would be working again.
I've read several posts on there being a bad relay that causes this issue, but I've checked and I don't see anything loose or warn on the fuse box under the hood.
Could this be a temperature sensor issue? Should I just change the blower?
I'm totally confused as what is causing this.
Tach_tech
5.7L HEMI
Does the blower motor just stop working completely or just some of the speeds?
Tach_tech
5.7L HEMI
I would start with checking for power/ground at the blower motor when it’s failed.
