cam shaft
  1. tx1500ram
    Cam lifter 2012 ram 1500 5.7L hemi
    My ram 1500 is at 135k miles, everything is solid on it especially the transmission and I just replaced the spark plugs and all the coil packs, I just got a quote for the camshaft repair and it was 8000 exactly. Is it worth getting the repair or just buying a new engine or trying to do it...
  2. R
    MMX Cam Swap - Tune Question
    Hi guys. I'm finished with my Cam swap after some lifter failure / cam failure on my 2013 Ram 1500 5.7 Hemi, and got everything back together. Ready to fire it up this weekend to test everything, but took a pause on the tuner side of things. I *think* i may have made a mistake with my order from...
  3. H
    Broken Cam Shaft Bolt
    I have a 2021 Ram 1500 with an odd issue around 30K miles. The Eco mode would cause a weird sound almost like a muffled Jake brake from an eighteen-wheeler, but only in Eco Mode. On the way into the dealership, the noise worsened and even stalled the vehicle twice in a less than 5-mile trip to...
  4. Gilberts Garage
    New Camshaft recommendation?
    Hey ya'll I'm new here, but have spent hours reading threads. I've been a GM/Chrysler tech for the last 13yrs so I have loads of experience in replacing parts. I've always replaced with oem parts, never installed a "performance" camshafts before. I have a failed lifter 4 weeks after buying my...
  5. Kustomblack1
    Daily driving 6 speed with cam and converter
    10 to 12 minutes of my trucks driving characteristics during normal driving conditions with a 3k converter and HPT cam shaft.
  6. Kustomblack1
    Thank you Moe's Performance!
    This truck runs great and sounds great thanks to Moe's Performance!
  7. Kustomblack1
    Big 6 speed holds its own
    This truck has MOE power! lol I love this truck!
  8. D
    Rebuilt Magnum 5.9L 2001 Dodge Ram 1500
    I have a 2001 Dodge Ram 1500 w/ 5.9L Magnum. I decided to have the motor rebuilt to stock with the exception of a slightly bigger cam and intake. Comp Cam Part No# 20-604-9 HUGHES FI AIRGAP KIT I purchased a custom tune from Performance Injection Equipment that would reprogram the ECM for...
  9. S
    Can shaft
    I am looking at putting a larger cam in my truck, it’s currently a 2012 ram 2500 with the 5.7 hemi, non mds. I was wonder what the maximum loft I can go is. I’m currently looking at one with the following specs and need to know if it will work. Most likely i will be putting this into a 6.4 eagle...
rockyj69
