tx1500ram
My ram 1500 is at 135k miles, everything is solid on it especially the transmission and I just replaced the spark plugs and all the coil packs, I just got a quote for the camshaft repair and it was 8000 exactly. Is it worth getting the repair or just buying a new engine or trying to do it myself. If anyone has done the repair before and could weigh in on if it's possible for someone with no real mechanical experience.
aszumilo
Navy Badge
Las Vegas
For $8000 I would look at a new motor. Seems way too high for a camshaft replacement.
Burla
2010 Hemi Reg Cab 4x4
It's really a regional thing, but generally speaking since the last 4 years did happen, 8 grand is fair.
It's gonna cost you 2-3 to do it yourself with hard to find parts and a bunch that need to be done a second time because pushrods bend, I'd use the shop, dyi thread. Many guys are coming back with well over 8 grand for this, dealers getting as high as 12-13.
For ishts and giggles I would call every local independent and ask them what it costs to drop a 5.7 jasper in there with or without delete MDS. Bottom line you have maybe the best year ram ever made for a hemi, I personally think so some disagree, whatever. You have 3.92's? I bet you do and I bet that is what the trans is so solid, if indeed you do have 3,92's and the 2012 with the 68 rfe it is worth saving.
Generally speaking you don't go from limited ability to dropping an engine in one step, but it is all about time and research. I never want to say cant, especially since cam jobs are hit and miss with pushrods.
jws123
nj
Shame your not close i do camshaft jobs for 2k. Use to be cheaper around 1400 but now since i have to buy oem lifters because no one makes good aftermarket those alone are $900 lol. A ton of vids on doing camshafts on these trucks its time consuming but not a terrible job you just need to follow instructions and do it the right way no short cuts.
tx1500ram
tx1500ram
Took apart my cam and my lord... It's been fully worn down. Going to have to buy a new engine. Does anyone know if it's really worth getting a new mds remanufactured engine
Burla
I think it is worth it, like I said 2012 is a very good year. As far as MDS/versus non MDS, if it is done right I'd prefer non MDS, but MDS does lubricate better. Obviously these hemi's are still prone to have cam issue;.
You can buy brand new complete Mopar 5.7's,that are basically an R&R job,as they come complete with everything.
jws123
nj
plenty of people including myself flush the engine out slap a cam and lifters in and have no issues its way cheaper my last truck had 3 bad lobes swapped cam and it ran to 230k before i sold it up to you tho maybe you have the money for a new engine im just cheap lmfaooo.
aepowell
My son bought a rebuilt engine in Dallas over a year ago. THe motor had everything replaced in it and I mean everything. It been over a year now and it has been a great engine. It cost 4100.00 installed with a year warranty. he drives it every day.
Garyriney
Tucson, AZ
I just replaced my engine at 260K.
If I were in this situation I would shop engines online and see if there are some you can option up. Buy an engine with an upgraded/hardened cam, upgraded lifters and a high volume oil pump. Also get one with an MDS delete.
BurtShaver
Ontario
That quote if 8000.00 seems awe fully high to me, I got a quote from Beattie Dodge about 2 months ago, 4200.00 including parts and labour for cam and lifters.
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
gtx6970
Tucson AZ
How can you do camshafts swaps for that kind of money. I assume this is parts alone
Ive got $3200 or so just in parts for mine.
I did all my own work on my truck ( retired Mopar dealer tech )
Had I known I was going to spend that kind of money.
I would have just bought a reman long block and been done with it
I was priced a Mopar reman for $5800
jws123
nj
How do you get $3200 in parts lol? are you rebuiding the engine or just doing the cam. The Lifters are 900-1000 IF you go oem Im trying a set of sealed power lifters next. The camshaft $350 felpro gasket set $170 Some people do the oil pump to another $120 depends on the person and mileage. I am able to do a camshaft job done in 1 full day depends on weather.
gtx6970
Tucson AZ
bought it all off Rockauto
OEM lifters.
Melling cam
complete Timing chain / gear set
felpro complete engine gasket set
all 4 MDS solenoids
Scat pack oil pump.
Parts and services locally
Heads done and removed 3 broken studs in the heads
exhaust manifold attaching hardware
oil + filter,
coolant
16 spark plugs
OEM lifters.
Melling cam
all 4 MDS solenoids
Scat pack oil pump.
oil + filter,
coolant
16 spark plugs
the 6.4 Scatpack oil pump is identical to your run of the mill 5.7 oil pump.The Hellcat 6.2 oil pump is the higher volumn pump.If you bought the 6.4 pump thinking it was the upgraded higher volumn pump it's not.Personally i'd rather use the stock 5.7/6.4 oil pump and up the idle rpm instead
jws123
nj
OEM lifters.
Melling cam
all 4 MDS solenoids
Scat pack oil pump.
oil + filter,
coolant
16 spark plugs
Looks like a good chunk of your $ was redoing the heads i assume? I rebuild my own heads ususaly just clean em up remove the broken bolts with a welder new seals ECT I also re use old manifolds after sanding them flat. I also never replace the MDS Solenoids as I tune them out.
gtx6970
Tucson AZ
Heads were only A couple hundred bucks I think. All he did was a vacuum ck to see how well they were sealed. Hand lapped just one in to improve it . They were not a But Just new seals and new OEM spings I broke one of the MDS solenoids upon removal, so just replaced them all . As I retained the MDS system
BHpgh
