coolant leak
  1. M
    Coolant leak
    Noticed a coolant smell and found a small leak around a hard line on the motor. Followed the line, starts hard turns rubber and connects to fire wall. Heater core line. Question is what’s this hard line called and is this easy to fix since it’s going into the motor? How does that fitting or...
  2. JPatterson98
    Coolant Leak
    Hey, me again. Got a new rack & pinion, so at least that problem was taken care of. But of course, something new has come up, this time being a coolant leak. Not entirely sure where the leak is, as I cannot get a decent viewpoint of anything. Seems as though maybe there’s a clogged line...
  3. B
    Gurgling in engine bay after shutdown, upper hose empty
    There are times I really feel like just taking a baseball bat to my truck! Today, after I got home after an uneventful 30 minute drive from work and turned off the truck, I heard some loud/noticeable gurgling coming from the engine bay. At first, I thought it was one of my kids thrashing...
  4. J
    Looking for Answers with what’s leaking
    Hey all, I’m not to knowledgeable with automotive ins and outs. I opened my hood recently and found what appeared to be dried up mud around the air filter box and a few other places nearby, I chalked it up to driving through mud. Today I checked under the hood again and noticed a wet orange...
  5. C
    Coolant Leak Down the Back of the Engine
    Hello, I know this is a common problem with Rams. It is a 2014 ram 1500 v6 3.0L eco diesel with 160K miles. It started leaking coolant down the back of the engine and leaks about 2 quarts every 15 miles. Does anyone have an idea of where the leak is coming from and the costs of the potential...
  6. D
    Unexplained Engine Problems (P0300, Unexplained Coolant Loss and Cruise Control Not Activating
    I have a 2005 dodge ram 1500 slt quad cab 4.7 Engine non-flex For the past 2 months, I have been having a p0300 misfire code (random intermitted misfire) and sometimes it will throw in a p0307 (cylinder 7 misfire) code. I have replaced my spark plugs in all my cylinders and replaced the...
  7. loudnproud
    Anyone know this part?
    First time poster here, long time reader. I'm hoping someone more experienced can help me identify a part number or even the name of the piece I'm looking at. I suspect it has something to do with the coolant but not sure. It's rusty and has started leaking a bit and I want to replace it...
  8. Ronin_Joe
    trans coolant line leaking
    Hey folks, Having some issues finding the right parts for my 2012 1500 5.7. The trans coolant lines seem to be leaking at the transition from hard line to rubber and then back to hard line. I have searched the forum a few times but not a bunch of info. I also cant seem to find the parts on...
Carbary
