cooling system
  1. C
    Radiator coolant level
    Is the radiator in a 3rd gen 5.9 supposed to be filled to the brim when the engine is cold? the expansion tank is full and I just bled all the air out of the system using a coolant funnel kit. Took it for drive then checked the radiator after it cooled down it was about 1 to 2 inches below the...
  2. 4
    The Curse of a 4.7
    Hey all! It's my first time using these forums unfortunately it's because there's no other alternative. I own a Gen 3 Ram SLT, with the 4.7 . Now don't get me wrong, it's not a bad engine like the fudds would have me believe, but I'm at my wits end trying to diagnose some issues. We have just...
  3. D
    Coolant Blockage?
    There have been some similar threads for my problem but I'm not sure if it's the same problem. It all started after I'd driven about 10 miles. Steam came from under the hood, and I lost heat. The steam was coming from the passenger side. I had it towed home. It looked like a leak but it...
  4. R
    Bubbling air in reservoir when shutting truck off
    I recently had some upgrades done on my ram 2500. Head gasket and revalving, studs for head, new exhaust manifold, new turbo with waste gate, 5" exhaust, egr delete, tuned. My problem is it seems to be building pressure in the radiator but the thermostat doesn't seem to be opening. The...
  5. R
    Coolant Cap cold,Top radiator hose is scorching hot, extremly hot heat, and no issues overheating!
    I just picked up a 1998 Dodge Ram 1500 5.2 with 100K on it, I have driven it and let it warm up to operating temp, and I notice that the radiator cap (which I just replaced) is bone cold, and the upper radiator hose is hot, while bottom one is cold. I have extremely good hot heat I have driven...
  6. Chrismb5.7
    I Need pointers on flushing coolant.
    So I bought an 04 single cab Ram 1500 with the 5.7 hemi about 6 months ago. To be honest, I've never owned anything like this and the most I've done to it so far was new exhaust system (headers, pipes, etc..) and of course the oil change. My fan clutch went out so I pulled it and now I wanna go...
  7. G
    AC ISN'T COOLING
    Hello from Dubai. The AC in my Dodge Ram/ Single Cabin 2015 isn't cooling anymore. Took it to 2 authorised service centres to have a look. There's no visible leaks under the hood. They say it could be the evaporator/ cooling coil which is a super expensive affair to fix out here (2,000 USD...
  8. StrokinThenCummin
    Normal Temperture Gauge Range?
    Hi all. I just replaced the wter pump, tstat, and coolant on my 04 5.7 HEMI w/ 195k miles. Before, the temp gauge stayed rock solid at about a quarter inch before midway. Now, it bounces btwn quarter inch and a hair before midway throughout driving based off of if I'm accellerating, if the...
  9. J
    2003 5.7 Hemi Coolant System Problems
    I’ve been having an overheating issue for the past couple weeks on my 03 Ram with the 5.7. To begin, for the last 6 months it has been running too cool. I attributed that to being the thermostat stuck open. A couple of weeks ago I finally replaced the t-stat and it started to overheat with the...
Carbary
