Hi there,
I have a 2017 ram 1500 with a 2” level kit. I have had a rattle for awhile now and figured it was my cv axles and differential shafts because of the play. I had those replaced and the rattle is still there. I have new struts, upper control arms, and new sway bar links. Anyone have an...
Alright guys need some advice/thoughts. so i did the cheap torsion bar key lift (1.5 - 2inch) and did 2 inch blocks in the rear. Now i did not crank them to match the rear, i kept a slight rake to it still. My first question is how does this angle look/can i go a tad bit higher. Second, is it...
