cv axle
  1. Jbal
    CV Axle Confusion
    Hey y'all, I've been looking through the forums and Googling but I can't find a solid answer. Short story long, my CV axle broke of course at the worst time, 40 miles from town at camp and I don't want to replace it out there in the cold. Can I just remove it and drive it back to town safely? Or...
  2. R
    Service Lights On After CV Axle Swap..
    11 Ram 1500 4.7l 4wd quad cab 130k Just changed the drivers side cv axle and now the SVC 4WD & ABS lights are one. I know I didn't damaged the Abs wire or sensor. Anyone else run into this issue?
  3. Ram7081
    Front CV axle bad? Card in spoke sound.
    Passenger side now has the card in the spoke sound when driving or coming to a stop. Even turning. It has an Eibach level lift. Its had a level lift on it for 25k to 30k miles or so. No offroad nor towing. Thinking CV axle? Thoughts?
  4. G
    CV Axle Clip?
    Hi... New here and to Ram trucks... Posting for my son.. He has a 2014 Sport 4X4... Describing to me what sounds to be the driver's side cv axle making noise. I looked at this Trakmotive axle on Rock Auto, TRAKMOTIVE CH8256XTT.. Says it does not come with a clip... I've done cv's...
  5. 9
    Front end rattle over bumps
    Hi there, I have a 2017 ram 1500 with a 2” level kit. I have had a rattle for awhile now and figured it was my cv axles and differential shafts because of the play. I had those replaced and the rattle is still there. I have new struts, upper control arms, and new sway bar links. Anyone have an...
  6. ginandtonic
    Hows this for a loose CV axle? (video)
    Does this look like rounded-off splines? This is the passenger side of my 2014 1500. I'm really not wanting to drop 525$ CAD on the inner shaft if I don't have to! Pulling off half the front diff would also probably be at the top end of my mechanical ability. What's everyone's thoughts on this...
  7. N
    Cv Axle replacement issues.
    I recently did my 100k mile inspection and found quite a few things that needed to be replaced. Everything ended up coming out great except for the drivers side CV axle. The old one had both boots tear open so I decided to just replace it. The ram dealer wanted like 600 bucks for a new one so I...
  8. J
    CV axle thumping/clicking noise will not go away
    2002 Dodge Ram 1500 I am desperate to figure out what is going on here but I am truly stumped. It started off with the tell tale CV axle tapping noise(in time with the rotation and occurring while turning). Pretty much everything under the truck was rusted out so in addition to the new cv...
  9. Mvansciver
    2012 ram 1500 cv axle and lower control arm trouble?
    2012 ram 1500 4x4 So im currently replacing lower control arms, driver side was fairly easy and everything came out without an issue, now the passenger side rearward lower control arm bolt will not come loose out of the bushing. Ive smacked it for hours with a 4lb hammer with no luck. The...
  10. Kepler
    CV joint issues?
    I have a popping sound when I press the accelerator and sometimes when I’m turning. For the accelerator it doesn’t matter if I am going up or down hill or what speed I’m traveling, if I take my foot of the gas for a second then reapply I can hear the single popping sound. Also if I come to a...
  11. Sho_Tyme671
    Aftermarket/Rebuilt CV joints
    GM Mopar fam. I am new to this forum so please bear with me. I was looking into rebuilding the front end of my '04 Ram 1500 4x4. I am starting with the CV axles due to boot failure of the drivers side and I know it's smart money to change both at the same time. I was looking on RockAuto and...
  12. Kepler
    Chirping from wheel wells
    So the Orange Crush just tapped 15k on the odometer and for the last 8k miles I have been dealing with a particularly annoying issue. I thought I would see if anyone else has experienced any similar issues with their truck or has an extra opinion what could be causing it. So the truck is a...
  13. Raist11
    Left side CV Axle repair - Short shaft reinstall???
    Why is everything online for the right side? I can not for the life of me find anything on the left side. Anyways, my CV axle grenaded so I'm replacing it. When removing the old CV axle that short shaft came out of the differential with the CV axle. I got that off the old one, replaced the...
  14. D
    2012 CV intermediate stub shaft
    I have a 2012 RAM 1500 4x4 and i need to replace my passenger side front CV stub shaft. I have everything removed but i cant get it to pull free from the diff. I have tried everything i can think of without actually removing the diff cover. The side of the shaft thats inside the diff is only...
jimn
