Nodean
I recently did my 100k mile inspection and found quite a few things that needed to be replaced. Everything ended up coming out great except for the drivers side CV axle. The old one had both boots tear open so I decided to just replace it. The ram dealer wanted like 600 bucks for a new one so I just went down to autozone and grabbed a duralast gold axle. Install was fairly straight forward. Had to replace the stub axle and seal as well. However now when I accelerate from a start there’s this ever so slight vibration. Something you definitely wouldn’t notice everyday but when I went for the test drive I definitely noticed it. It also only happens in 4WD. any ideas as to what this could be? Is it possible I missed something during the install.
Bonus points if someone can give me a good recommendation for an AC compressor pulley replacement / full compressor replacement (dealer wants 400 and 1k respectively for the parts which is crazy)
