factory air suspension
  1. OurTimeToRV
    AlfaODB Air Suspension Ride Height Change
    I have a 2016 Dodge Ram 3500 DRW with factory auto leveling air suspension. My question is, has anyone used the AlfaODB app to change the ride height on their air suspension? And if so, is it just one parameter or is there a Driver and Passenger separate height setting? In essence, I would...
  2. J
    Need Advice for Suspension Lift on 2018 Ram 2500 with stock air susp
    I have a 2018 Ram 2500 Limited 4x4 Mega Cab with factory air suspension in the rear. I would like to keep the factory air suspension. I want just enough lift to fit 35 12.50s and have zero rubbing and no trimming. Also maybe improve on the factory air suspension. I'm aware most likely I will...
  3. GoBlueRAM
    Factory Air Suspension vs Airlift Loadlifter 5000
    What's up folks! So I'm finally upgrading to a 3500 SRW from my 2500PW. Currently I have a set of Airlift Loadlifter 5000 bags with schrader valves tapped into my bumper. This is mainly for anyone who has been in similar situations, or have used either or both options and have real world...
