front suspension
  1. DeadEyes
    Suspension upgrade
    I have a 2017 ram 3500 SRW 4x4 and I'm looking to upgrade the whole front suspension and steering. I don't want to cheap out, but I also don't want to spend $1000 on ball joints. The truck is used for hauling and parts are wearing out, and I'd like to get onto replacing parts before they...
  2. Halfdane
    2016 ram 3500 4wd control arm shock absorber
    2016 ram 3500 4wd DRW white flatbed 6.7 turbo diesel 290,000 miles I am in the process of replacing the upper and lower ball joints for my truck. When I was looking at the front suspension system for my truck, I noticed a shock absorber that is horizontally mounted on the control arms (I...
  3. RamShark1
    2015 2500HD 4x4 alignment, recall issue, Help
    Hello Everyone- I need some input on my 2015 2500 4x4 currently in the body shop with a front alignment issue probably from a hit and run front left swipe. My right front tire started wearing fast. I though maybe it was just one of my aggressive driving moves and blew it off, unfortunately I...
  4. Z
    newbie questions on front suspension
    Hi. So I have a 2010 Laramie 4x4. Just took it in for a check up and was advised my front tie rods are showing a little slack, and front bushings are going to need replacement soon. I was wondering if you all could tell me if there are replacement parts out there that are better than stock...
  5. jh90731
    vibration / front suspension?
    My 2014 Express 4WD suspension with 73k miles is completely stock. Lately I’ve been experiencing some vibration throughout the entire truck. Not necessarily through the steering system or at the steering wheel. Last week I had the tires rotated and re-balanced at Discount Tire and it seems to...
  6. T
    Front End Issues - 2018 2500 6.4L gasser
    This is my first 2500. I've had 3 1500's including an Ecodiesel over the past 10 years. I bought it used with 8200 miles on it. The first thing I did was replace the Firestone AT's with Michelin Defender LTX tires. About 1000 miles later, the front end feels loose and rattles going over any...
Carbary
