help identifying
  1. E
    Loose Handling
    Would bad rear leaf springs make get loose handling? Switched gear box in my 2007 dodge ram 2500.. whole front suspension parts are new, and still feels like i cant control my truck, Will be trying to go straight and makes me move as if im a drunk driver! Left and right, Hate how much money ive...
  2. Y
    Mystery metal on trans drain plug, Help!
    Hey all, recently my 2004 5.9 with a fmvb 48re has been reluctant on the 1-2 shift and after getting it home it refused to 1-2 shift at all. I pulled the drain plug on the pan and while the fluid didn’t look great it wasn’t anything too unexpected for 25k miles on a fresh build but attached to...
  3. G
    Engine noise, want ideas for more verification
    Ran into a new noise with my engine. Truck is already pulled apart down to cam and lifters I will upload pics next time I think of it. I am already aware of exhaust manifold fail that was a pre existing issues but this noise randomly devoloped on driver side, the exhaust manifold fail was on...
  4. B
    Infamous steering wheel control issue has me stumped
    Truck 2015 Ram 1500 tradesman. Motor swap performed before I bought it donor motor was a 2017. Ivr had the truck 2.5 years and steering wheel controls have never worked. Guy I bought it from said they worked before the swap, but I dont know if I trust him. Cruise control and gear selection...
  5. M
    Odd transmission problems 2014 ram 1500 8hp70
    I have a 2014 ram 1500 5.7 with 8hp70. When the truck is idling and in park, the digital speedometer says 1mph. Then when I put it into drive and go above 5mph it puts itself into park and stops me. I tried pulling the lever to keep it out of park and it does a similar thing where it revs up and...
  6. Mytruckbetterwork
    Someone please help! 3.0L eco diesel
    I drive a 2015 dodge ram 1500 3.0L Eco diesel, lately I’ve been having some kind of electrical issue. What’s been happening is it takes a minute for the battery to get to 14V, once I start driving after letting it run for a minute it flashes on the screen “battery low voltage” and the voltage...
  7. 2
    2005 Dodge Ram - What happened to it?
  8. S
    Insane Fuel Consumption.
    2008 Dodge Ram 2500 Hemi 5.7L with 4x4. Until the last couple of months I had roughly 12 miles per gallon. I dont know what has happened, but when I noticed an employee was filling the tank every other Day; I averaged it again and it came out to 5 to 7 miles to the gallon. I have already pulled...
  9. Elik14
    Eps module capacitor
    Been having an issue with eps and may have found the source of problem. And was wondering if anyone knows where to find these capacitors.
  10. C
    Cold Starts
    Just wondering if anybody can weigh in on my truck. When I start it in the cold(winter here in Canada) it seems to sound flooded. I bought the truck used, it has an h & s Blackmaxx tuner, and I was told it has 120 over injectors. Would oversized injectors at -20 Celsius cause this? Or should I...
  11. R
    Engine Stalls when Brake is Released
    I have a 2003 Ram 1500 with the v6 engine. As of the past few weeks, the engine would bog down to ~400 rpm when releasing the brake when stopped. Last week, the engine died. not sure what the problem is, as no codes have been thrown. Any advice?
  12. John_Eagle13
    2013 1500 5.7 Potential BCM issue?
    Hey guys, brand new here. I've been tuning my truck for about a year now, by myself, with my own hardware. Up until about a month ago I've had 0 issues till I made a mistake loading a tune into the truck and corrupted the PCM. Long story short I bought a rebuild PCM and put it in last week. I...
  13. P
    06 1500 lock cylinder component identification
    the other night there was an attempt to steal my truck and a lot of the immobilizer parts and the lock cylinder parts where damaged am having touble identifying a part if anyone has any ideas or part numbers would be much appreciated
  14. L
    Please help 2006 dodge ram 1500
    My grandfather passed away in January and this was his vehicle, I have it now and this is hanging under the truck the piece that broke was in the driveway is this the fuel pump? Does it just need clamped back up? Please help
  15. B
    She’s lived a long and adventurous life
    I’ll be Ramin or Dodgin until I die. Grew up bouncing around in a loud 24 banger ask my grandpa to flip to the B side of “The best of ZZTOP” bought my dream truck with 24,000 miles on it. 2013 Ram 1500 Laramie Longhorn. She changed my life, freezing my butt off just to lay my hands on her warm...
  16. H
    Suspension noise help
    So I hear a noise from my suspension which kinda sounds like a thud. I hear it going over bumps and I decided to steer left and right to hear if the noise appears during that and it does. I hope that will narrow it down I still wasn't able to check it out but I would like to get an opinion from...
  17. K
    Clicking noise front end drivers side
    So I my drivers side cv axel broke and just put a new one in. While I was accelerating, you can here a constant clicking noise that speeds up when I I give it gas. Noise is coming from front drivers side. New upper and lower ball joints. Any suggestions?
  18. H
    rpm moving up and down while driving Ram 1500 SLT Hemi 5.7
    I noticed when im driving on the highway steady speed also my rpm moves up a little bit on its own exactly how it does when you're on cruise control and bump it up by a number. Can anyone help me identity whats the cause is and how to fix it? Thank you.
  19. H
    Need Help identifying hose connection
    So, while changing my sparkplugs I noticed this hose just laying there and I couldn't figure out where it should be connected to.
  20. H
    I need help to replacing this part (picture attached)
    on my 2014 Ram 1500 Slt 5.7 Hemi, I need to replace this broken part I'm not sure what is it called specifically but it is located in the front passenger side. Can someone send me a link to a replacement from Rockauto, please? Thank you!
Carbary
