interior light
  1. C
    Map Light Replacement
    I have been researching ways to change out the map light due to dimming a flickering, and kept seeing that you had to replace the entire console or cut off the plastic pegs. I found another way on my 2018 Ram 1500 Sport with the LEDs. If you stick a trim tool in between the black plastic and...
  2. Auie
    2016 1500 SSV - cab function
    Hello, I recently purchased a 2016 Ram 1500 SSV (special service vehicle). I really am enjoying this truck. There are some things I’m wondering if someone can help me figure out… 1) how to re-enable the rear doors so they unlock and passengers can get out without help from the outside (was a...
  3. J
    Map & Dome Light on '15 Ram 3500
    This is an odd one that I cannot figure out. I have a 2015 Ram 3500 Tradesman. At night, when I unlock the truck or open any door the interior map and dome lights do not come on. It does not matter which direction I spin the wheel that is placed on the left side of the steering wheel. However...
  4. Marc Taylor
    Driver / Passenger Interior Light Switch Failure
    One side broke in the ON position, so I removed the bulb on that side and drove on with just one side. Now that one is broken as well. Any way to replace these switches without replacing the entire overhead "console?" Thanks
  5. pavementprincess
    Instrument/Gauge/Odometer Cluster - 02 1500
    I've researched this a little online, and seen similar issues on other Dodge Rams and other brand (i.e. Ford) trucks: my Odometer light on my instrument cluster fades in/out, and has been getting progressively worse. Its to the point where the Odometer light on my cluster is out for a week or...
  6. L
    Changing Interior LED Door Handle and Storage Colors
    Hoping to get some answers on how to change your lights in the interior of the doors. My 2014 CC Ram 1500 Limited has the factory blue and would like to change it to red. Has anyone been able to change this?
  7. W
    interior light don't work...
    Hallo I own a dodge ram 1500 slt 4.7 from 2003 and my interior lights don’t work anymore. When I open or close the door or use the ‘switchwheel’ they don’t go on or out. I have checked the circuitbreakers under the hood and they are fine. The reading lights work well. (pushing them)...
  8. TRANSMITTERGUY
    Interior lights don't come on at night?
    I installed LED interior light kit in my overhead light console and back seat light, now they dont come on at night, when I open my door, or manually turn them on ,with the interior light switch by the headlight knob. What is going on? They do, come on, when I unlock my doors with the key fob...
jimn
