oil pressure
  1. O
    2023 with 3.6L Oil Pressure gauge on dash
    Just purchased a 2023 RAM 1500 Classic and I wanted to make sure what is the correct range for the Oil Pressure Indicator. The needle is just slightly left of middle- is that a safe pressure range or is it too low? If it is too low what repairs / changes are needed to bring the pressure up...
  2. T
    5.7 MDS issue again but getting less
    Could a higher pressure oil pump cause issues with the MDS deactivation or reactivation and throw a code? 5.7 So I posted on this before with the weird MDS deactivation issue code but it's not specific to one cylinder it was originally and we had a problem with a head gasket on that side It...
  3. B
    4.7 oil pressure next steps
    I’m brand new here, and I know this is an old tired topic, but I’ve searched for further answers with no luck. This is going to be long winded. I apologize in advance. Another caveat is: the only mechanical knowledge I have is what I have learned from the internet while doing all my own...
  4. S
    Truck wobbling and seems to have low power when in drive after oil pressure sensor replacement
    Truck threw a check engine light at me this morning and the code was indicative of an oil pressure issue. (Reading 99psi, super high, at the time) O’reillys scanner suggested changing the oil pressure sensor. “Cool, easy peasy” so I thought. Easy peasy on Hemi’s, frustrating enough to make me...
  5. D
    Low idle oil pressure, after high volume pump install.
    2011 ram 1500 5.7 So I recently replaced my MDS lifters with non-MDS, replaced the oil pump with melling high volume oil pump, and installed an MMX NSR NTR camshaft. I also switched to a slighty thicker M1 5w-30 oil. (MDS delete purchased through moes performance.) Cold start: 80+ psi...
  6. M
    2015 5.7 L Hemi oil pressure issue
    Hello, my check engine light came on and I started getting low oil pressure so pulled the codes reference photos. Started with an oil change and oil pressure sensor replacement. While I was doing that I found metal shavings I finished the oil change and kept driving it after clearing the codes...
  7. C
    Digital oil pressure reading at 100PSI but L and H oil pressure gauge reading normal. Check Engine Light on
    I have a 2016 Ram 1500 3.6. The check engine light came on and the oil pressure is reading at a consistent 100 PSI when idling and when driving. My L and H gauge is reading normal and appears to be functioning properly. Is this simply the oil pressure sensor needing to be replaced? I hear it’s a...
  8. Z
    Check Gauges light going on & off
    Hi, Checking to see if anyone has had a similar issue as I am having. I have an '05 with the 4.7. The "Check Gauges" light goes on and off many times while driving, and while the light comes on, the oil pressure gauge drops, but most of the time by the time the gauge gets all the way down, the...
  9. C
    MDS P1524
    I had a droning/whining noise intermittently while driving my 2019 Ram 1500. I had it looked at and was told that the most likely issue was MDS Solenoid. Currently do not have the extra funds to get it replaced, permanently deleted, or to leave my truck there and get an in depth inspection...
  10. R
    Oil pressure
    I recently had an oil change 5w-20 and filter changed on my 2019 Ram 1500 5.7L. When I start the truck it displays 0 psi for then jumps to around 55-60 psi within seconds. Drove around the block about a mile and a half turned off the truck and the psi drops to 0. I’m monitoring this through the...
  11. T
    Random Oil Pressure Readings & Hard Start (Before and after engine rebuild)
    To begin with, about 3 months ago my 5.7 liter hemi 2005 dodge ram 1500 ran into a massive amount of problems all in one day. These issues were, loud knocking, stalling, misfires, hard start, and many other things. One of the smaller issues was the oil gauge dropping to 0, this would eventually...
  12. J
    292 Oil Temp??
    Hey guys I was just cruising and my oil temp was at 292° F and my oil change light came flashing on. I just did the oil just under 3,000 miles ago. Outside air temp was 30° F. Water temp was slightly above half on the gauge. Oil pressure was reading 3/4 on the gauge. I’m at 130,000 miles and...
  13. A
    EcoDiesel No oil pressure
    I have a 2015 ram ecodiesel. I was recently going on a trip and got about 30 miles from my destination when I decided to make a quick pit stop. Truck was running fine. Then it started saying no oil pressure when I started the motor back up. If I gave it fuel the oil pressure would go up and the...
  14. S
    Oil Pressure
    So I bought the truck in February had no issue up until last week, when p1524 code popped up, and my oil pressure at idle would stay at 27 and during driving it would not go above 31. Freaked out a little, after a little research found out its a oil filter issue. Got a new oil change using Pup...
  15. D
    Chasing ghosts....
    2007 1500 5.7 hemi 163k - 30 miles into highway drive today I suddenly lost power and oil pressure according to dash - check gages light came on. Checked all fluids and FULL. No sign of leak or dump of fluids. On side of highway, replaced battery (bad cell) and had alternator tested (passed...
  16. grandpajohnson
    Oil Pressure
    I have a 1985 Dodge D150 with a 360. My oil pressure on my dash is reading high. Can yall explain testing oil pressure and diagnosing the cause? What's in the picture? Oil pressure switch? sending unit?
  17. Ram2017_64164
    Oil Light Came On; pressure showing fine (?)
    Hello everyone, I recently purchased a 2017 Ram 1500 Limited with 34,000km. I’m now at 36,564km and the oil light came on. The truck sounds fine and the pressure gauge is at the middle. The oils is down slightly but where it should be for the km’s driven from its recent oil change. I do have...
  18. NY Andrew
    Oil Pressure/Temp about right?
    So I just did my RAM's first oil change. Switched to Red Line 5W20 and Royal Purple Filter. I'm sure we all feel this way after an oil change, but it seems SO MUCH SMOOTHER. Even after only having 3k miles I swear the Hemi tick is gone...what little bit I did have I can almost not even notice...
  19. connor98
    Shift patterns
    I have a 2010 1500 5.7L sport 4x4 and I just had my camshaft replaced along with a few other parts related to a limping cylinder. Before the repair my truck would shift at around 1800rpms now 1st -2nd @ 2000rpms 2nd -3rd @2000rpms 3rd-4th @ 2500rpms and same for 4th-5th. Though while driving it...
  20. E
    1997 Ram 1500 won't shift into overdrive
    1997 Ram 1500 4x4 5.9L V8 160,000 miles Won't shift into overdrive and burning through a quart of oil every 75 miles roughly. Any ideas on what the problem is?
  21. grandpajohnson
    Oil Pressure Flucuating
    Hi, My first post on the site. I have an 85 Dodge D150 with a 360 engine. I noticed about a week ago that my oil pressure gauge on my dash was reading high, a couple dashes below all the way to the top. Usually, it sits right in the middle. I checked the pressure using a pressure kit and it...
