1997 Ram 1500 won't shift into overdrive
Ejwallin
Wisconsin
5.9L V8
1997 Ram 1500 4x4
5.9L V8
160,000 miles
Won't shift into overdrive and burning through a quart of oil every 75 miles roughly.
Any ideas on what the problem is?
dapepper9
Iowa/Nebraska Border
5.9L V8
For the oil burn:
Comp test, both wet and dry.
Inspect plugs
The trans issue is going to require more information about how exactly it acts. For example, when it won't go into overdrive, set the cruise and note how it reacts. If no change, click the OD on/off switch. Note any reaction.
Also the trans likely needs a good fluid/filter/band adjustment. But we'll get to that
