radio issue
  1. B
    7” Screen not working - 2013 1500 Big Horn
    My stock UConnect LCD screen has mysteriously stopped working. I started the truck, saw the LCD screen start to boot up properly, but then it flickered and then went out. It’s been displaying nothing ever since. Checked the hidden radio fuse, it’s still good. Disconnected my negative...
  2. nevinc
    Issues with 2024 HD 2500 RAM
    I bought a new 2024 RAM 2500 HD and have had to jump start it every day since I got it. Dealer said battery is good and they had no problem. I don't know what to do to get them to understand that every morning I go out to my truck it is dead. I have verified the usual, nothing is left on, I...
  3. I
    Black screen after failed update
    I pulled up to the house to pick my son up and when I turned the truck off saw a message that there was a software update available. It said the ignition had to be off and the vehicle in park to install, so I hit install update and got out of the truck, thinking it could install while I ran...
  4. T
    2019 Ram 1500 radio/climate issue
    Having an intermittent issue with my new to me ram truck when I start it up the radio will sometimes not power up and causes the climate to put out hot air. Only had the truck a few months now and it seems to be related to hot weather as it didn’t have issues in the colder months. Weird thing is...
  5. L
    2017 Rebel radio dead short.
    2017 Rebel radio dead short! Radio screen was dead this morning after working fine yesterday. Checked all fuses and stand alone was blown. Attempted to replace and instantly blew again. It was 20 Amp but believe there is a short. Any trouble shooting tips?
  6. dehdlee Duo
    Stereo is now not working after Heater core replacement
    Hey all, I have so many questions but one thing I wanted to find out if anyone else has dealt with this problem. I took my truck in to get my heater core replaced manily cause I don't have a garage and didn't want to be in the cold to tackle that. Anyway I would like to find out if I may be...
  7. S
    Radio problems
    So I was heading home from work and the radio suddenly cut off. Tapped it a few times and nothing. Started playing around and found that my satélite radio worked, just not my fm/am. Didn’t think much of it, looked some stuff up and thought it to be a fuse. Got home and checked my fuses and they...
  8. Fredheim
    Radio problems ucoonect
    Hi all. Im new here. I have some trouble whit my 2016 ram 1500. The sterio freezes up. I have no volum control but can swich from am to fm. When it starts up there is sound in the speakers until the watch comes on. Then its silent. Cant ad phone. Also goes back to default in settings everytime...
  9. S
    New stereo install issues
    Hey y’all so I have my 2012 3500 Laramie and I did a radio replacement as this old oem one just isn’t cutting it anymore. Now that she’s in and ready to go I noticed I don’t have video from my rear view camera. Like the new head unit knows when I’m in reverse and is looking for a video signal...
  10. B
    08 Ram 1500 only one speaker has sound
    Hey so I have an 08 Ram 1500 with the stock stereo. When I got the truck none of the back speakers worked and the front passenger was blown so I replaced the front speakers for new ones and shortly after all but the front driver door speaker stopped working. I thought that it was the radio...
  11. J
    Uconnect 8.4 faults
    I have a 2015 1500 outdoorsman. My first issue I found with the radio is my built in nav doesn’t work (either doesn’t load anything or will say I’m 100 miles away from where I am) now my biggest issue is the whole unit will take up to 5 minutes to turn on after turning on the truck. Not sure if...
  12. Matthewk88
    Electrical issues and park sensors
    I just bought a 14 ram 3500 Laramie and found a couple issues with it. 1. The channel down and volume down buttons on the steering wheel do not work but all other buttons do. 2. If I turn the radio volume up to 22 or higher the audio skips and even cuts off but if I turn it back down to like 10...
  13. TomRF
    2020 Ram 1500 Laramie with crap 12” U-connect
    I’ve seen other threads with people who’ve had issues with the 12” U-connect screen. As of now, I have 17k on my truck. I’ve taken it to the dealership 14 times starting at 1250mi all the way through 14.5k mi. They swapped the radio out twice and replaced the original radio with two refurbished...
  14. BenWH
    Uconnect 5.0 Radio Issues
    For the past month or so the radio in my 2015 1500 has been glitchy. Every two minutes it will reset itself like I just turned on the truck and go back to whatever station I had it on. So I’d be listening to a station and it would cutoff and 20 seconds later I’m back on a different one. The...
  15. B
    A/C and radio not working
    Hey guys, 2013 1500, radio completely died today in middle of a song, ac stopped working at the same time, all fuses I’ve checked are fine, if I disconnect battery cable for a few minuets and reconnect, the radio flashes for a second then shuts back off. Anyone have any ideas? Thank you
  16. countrycoolio@yahoo.com
    Head Unit freezing up ( help/advise)
    My apologies if this has been addressed in a prior thread, but I searched & did not find anything. I have a 2011 2500 Laramie Longhorn 6.7 & it is equipped with the Alpine speaker package with a Sirius "RHR" head unit. This head unit has a habit of completely freezing up... meaning none of...
