0-60 times
rocket
Licensed Dynacologist
Pennsylvania
was 2006
was a HEMI 5.7
I was curious, last time I checked it was when I had the 22s and a CAI and that was it....
Not too bad for a little spin out of 1st and 2nd gear scratch...
I need to get my bf to drive my truck and see what it will be, he can drive a lot better than me and not spin the tires out of a dig LOL :crazy:
Uh, smaller tires with the same tune(big tires) will yeild a faster than real reading...6.34 is quick. I managed 7.10 on a stock sized tire, (michelin's). Ya might try a quick tire size , retune...and try again w/ or w/out the bf.:birgits_tiredcoffee
ralaubach
CA
2007 Ram QC
Just got a trinity today so i figured i would go get some times. first one was 7.6 second one was 7.9. tire spin on the second one.
mod on the truck right now. CAI, powerwire, 85mm TB, tranny boost line, trinity can tune (perf.87+).
Kind of slow I relies but the tires need to be replaced with some that have decent tred, has a full tank right now, and it is just 89 octane. I think with a fresh set of tires, less fuel and a 91 tune should bring those number down close to 7.0 range.
rocket
Pennsylvania
was 2006
was a HEMI 5.7
Nice respectable numbers....nuttin wrong with that.
HemiLonestar
Navy Badge Coast Guard
MD
Before converter swap and 4.56 gears. I need to do a new one.
ralaubach
CA
2007 Ram QC
Well got the new tires on (Nitro T555) and the fresh oil change. put the trinity to 91 octane setting and pulled a 6.69. Not to back for an 07 5.7L QC with a full tank of gas.
Injen CAI, Fastman 85mm TB, Power wire, tranny boost line wire, Diablo trinity (91octane), 2'' drop shackles.
Now to find me some headers and get some 4.56......
ralaubach
CA
2007 Ram QC
San diego, Also fred I saw your list of mods and basically using it as a check list for my truck. Except the 2/4 drop that is. That is one quick hemi....
ralaubach
CA
2007 Ram QC
Going to take it to an 1/8 mile track we have here in san diego tonight. I will post the results tomorrow morning hopefully.
ralaubach
CA
2007 Ram QC
Had a hard time hooking the wheels up. But now I have some base times to see how the next mods help improve or not.
Took the tail gate off, spare tire off, and had about 3/4 tank fuel. next time going to get the fuel much lower. and run the 93 performance tune. found a place int SD that had 100octane. now just to do the equation for mixing 91 and 100.
07 QC 2wd 5.7
Mods: Injen CAI, power wire, 85mm TB by Fastman, tranny boost wire, trinity tuner on 91 octane, Nitto NT555 265/40r22.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
You dont have to mix the gas perfectly to run that 93 octane tune. It is better to play it safe though and be on the high side.
Were you spinning on those passes?
ralaubach
CA
2007 Ram QC
Typically. Also if it was not obvious, I was right lane on both of those. Entry 6307. I am thinking the next thing is going to be an LSD, 4.56's, new cover for it all and Caltracs. The power is there, The traction is not....
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
The mods you mentioned are going to show a huge improvement in your times. Having a powerful engine doesnt do much good when you cant put that power to the ground.
And I know the mod list is starting to get up there in price, but a higher stall converter is also going to show major gains at the track. Many guys have dropped as much as .3-.5 with a converter alone.
ralaubach
CA
2007 Ram QC
yeah, need to get the power down first. 600hp is great, but if you can put it to the tire.... your just burning fuel and tires.
garner
Harker Heights, TX
You would probably benefit from wider tires too. My R/T could spin 285 pretty easily and this new truck will spin 275 every once in a while, both were/are bone stock
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
Thought it would be harder to spin 285 vs 275 .... wait i did not factor gears for your rt vs now
Sent from my ASUS Transformer Pad TF700T using Tapatalk 2
garner
Harker Heights, TX
Oh gotcha. My guess is 4.10 gears vs 3.55 and the different stall speeds. Plus the R/T was around half a second faster than the new truck. Now that was with stock tires, once I went to nitto 420s on the R/T it would never really spin anymore
Edit: Oh and shorter tires, 32" on the R/T vs 33" on this truck
