01 ORE ram 1500 lift help
bassslayer25
East, Kansas
5.9 360 V8
The highlighted is ********. Just because you haven't noticed a problem doesn't mean there isn't one and everybody's definition of "fine" is different. You did the half assed way of lifting no ifs ands or buts about it
Anymore I just assume all my **** is under stress.
dapepper9
Iowa/Nebraska Border
5.9L V8
My truck was already lifted from the factory. All I did was basically extend my springs by 2.5 inches. It barley if not at all changed anything else about the suspension
Yes your truck was 2" higher which means a 2.5" spacer is 4.5". The problem is the spring is the lift parts on the ore. Control arms are no different, steering parts are no different. Which naively means you have 4.5" of lift on a standard 1500. Bad juju
dannetb
Eh **** it. If it breaks then I can justify buying a 7 inch lift
1SilverBullet2
North Dakota
2014 Big Horn 8 speed
Yeah and don't try killing somebody in the process when a steering component goes out when you're driving down the road...FFS
dannetb
It's cool. I'll aim for the bushes
phorrestphire
