01 Ram 1500 Front End Squeak/Squeal????
daredevil95
Hi, i have a 2001 Ram 1500 4X2 with a horrible front end squeak on the driver's side front tire. I pulled the tire and the squeak went away. With weight on the tire it squeaks and I can't find anything broken or loose. What the heck is this and where is it coming from?? I made a short vid of the sound and hopefully someone will know what this is???? There is nothing wrong with the steering or any bangs or knocks coming from the front end. It steers perfectly straight so, just an annoying squeak. Let me know what you guys think and thanks in advance.
https://www.youtube.com/watch?v=OYDzJuMaJn4
bananahamikthe1st
5.9 v8
Sounds like either a bad bushing or joint..or the worse sounding steering stabilizer ever...my money is on those ball joints..which I assume is what your greasing when the sound goes away
Sent from my SAMSUNG-SM-G930A using Tapatalk
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
What part are you spraying the grease on when it goes away..
daredevil95
daredevil95
I sprayed pretty much everything, the up/lower spring seats all of the suspension and outside the ball joints. I bought this truck new and those ball joints have looked like that for at least 12 years so, IDK? I guess i could change everything including the original shocks but, heck, I was hoping someone else experienced this before. Thanks
daredevil95
daredevil95
I pretty much sprayed everything with WD40 the first time including both sides of the spring and up into the shock and it went away for a couple weeks then came back, the white stuff you see in the video is white lithium WD40 grease I used at a friends house and it cleared up the squeak for a couple weeks but, back again and I'm tired of spraying crap on it and want to fix it. As you probably know, we dodge owners hate going to a shop to pay for work so, I gotta figure it out and I would hate just replace everything......which is still cheaper then bringing it to a shop to fix the one problem. IDK....I'll keep trying. Thanks for the response
bananahamikthe1st
5.9 v8
Could try greasing one thing at a time until it goes away.
daredevil95
daredevil95
I'm gonna guess at the ball joints being the issue. Any recommendation for what/where to buy the ball joints?
dudeman2009
Magnum 360
autozone, autovalue. Really any place that sells a brand you trust. Most all autozone duralast parts are moog private label parts. They are easy to change, 3 bolts and 4 bolts (cant remember which one is upper and lower). I got both sides replaced in about 2 hours. Technically you need an alignment afterwards, but I replaced mine and went in to have the alignment checked at work and it came back perfect.
daredevil95
daredevil95
I ordered all 4 from RockAuto for $122. The ball joint is mevotech and the online reviews say there pretty good and comparable to Raybestos ball joints. So, I'll see how these go and if they are crap then at least I have the rivets drilled out and all I need to do is unbolt and replace.....easy!
