02 durango vacuum leak?
azdurango
2002 durango
i have a question about the 4.7 v8. i was hearing a air leak when the engine was idling, when i tracked it down it was coming from one of the ports behind the "hat?". both ports had a cap on it,but 1 of them was cracked. when i put my finger over the port, the engine would start to choke. it seems like at idle this is the only air the engine is getting.
when i take both caps off the idle speed goes up.:help:
at idle i noticed that there was no air being drawn in from the air filter. when the engine is revved it does draw air.
is this normal for magnum engines?
A
azdurango
2002 durango
i didnt think it was. what is the large square part on top of the engine?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Sounds like you have a combination of a vacuum leak as well as an IAC valve failure on your throttle body.
I would be removing the air hat and throttle body to inspect closer for anything else that's broken.
