no start
  1. Oxygen454
    No Start without pressing gas
    I have a 2013 with the 3.6L. When I start the truck on cold days, I have to press the gas pedal. If I don't press the pedal, it will keep turning over but wont start. Once it starts, it runs fine. If I drive and shut it off and wait a few minutes, it starts right back up. If I start it a couple...
  2. D
    One Click No Start issue. 2018 5.7
    First time posting here so I’ll try and keep this short. About 6 months ago I found my self stranded in a parking lot after my truck was not starting… just one single click. After about 10 tries trying to start it, the truck fired up fine. I went on about my day and the truck was running and...
  3. L
    05 2500 No Start - Where to look
    Picked up a new to me 05 2500 5.7 for dirt cheap, lots of work ahead but overall solid. Picked this up last week from a guy who had someone attempt and steal it, messed up ignition then cut the cats, as far as I can tell that's the most of it. Now the sadness, I've been unable to get the starter...
  4. T
    Crank no stat 01 cummins
    I have a 2001 dodge ram 3500 that I just did a new clutch in and put head studs and gaskets on. It will crank but won’t start it seems like it’s trying at times. I have fuel up to the injectors. I’ve done everything I can think of so I came here for some help.
  5. G
    Rebuilt hemi backfiring through intake
    I have a 2006 ram 1500 mega cab with the 5.7 hemi with no EGR. I bought a junk yard motor and took it to be rebuilt at a machine shop. After I installed it I tried to start it but problem is that it wouldn’t. I checked spark and fuel. Both were good. I checked compression and all cylinders had...
  6. P
    No electrical power.
    I've got a 1994 Dodge ram 1500 2wd 5.9. Issue started just a few days ago. Tried starting truck and battery voltage on dash showed almost no voltage at all. I then messed with the battery terminals they had no movement. Jumped back in the truck and it stared no problem. Got a few miles down the...
  7. T
    2003 RAM 1500 5.7L CRANK/NO-START, NO PCM COMMUNICATION
    I need some help. I can get it to idle off of B12 but will crank/no-start without it. Hooked a Dodge scan tool on it and it says PCM has no communication with other modules. Fuel pressure is good and noid light indicates injectors are firing. There is spark. Any suggestions?
  8. M
    Ignition Problems after rain 2019 Classic
    Left the windows open like an idiot and it rained, and now the truck won't start (2019 Classic 3.6l w/80,000 miles). It;s been a few days of hoping that drying out will help. Here is the info I have so far: -battery seems to be working fine, the usb ports still charge my phone, power locks still...
  9. 2
    No start, no bus. TIPM and BCM replaced
    2013 1500 big horn 4x4 Hemi. Turn Key on acc and dash boots as normal, like nothing is wrong( or it dosnt come on at all like it's dead and guages TWITCH). When I turn to ign on, then everything loses its mind. Shows tire pressure and everything seems normal for a second then everything goes...
  10. Mack93
    Starter grinding flex plate teeth
    I have a bone stock 2021 ram 3500. 6.7 Cummins H/O hooked to a Aisin transmission. Truck has 162k miles. Original starter solenoid went bad. Had it changed out. 3 days later on a cold start I heard a grinding noise and truck wouldn’t turn over. I new what it meant. Towed the truck to a shop...
  11. B
    2002 5.9… no fuel or spark. Bad pcm?
    Hey guy, I’m working on my father-in-law’s truck and I believe the pcm is bad, but I wanted to get some second opinions before jumping the gun. The truck supposedly would run fine but then going down the road, the gauges would flicker and the whole truck shuts off. You could wait a few minutes...
  12. R
    2012 2500 RAM Non-Continous Crank & Start
    I accidentally discounted my positive battery cable (instead of negative) for several days to do some work on the truck, and now it has intermediate cranking. Meaning that sometimes it will crank/turnover once, sometime three times, and sometimes not at all. No matter how many cycles the engine...
  13. tscarber
    No Codes, No Start
    Recently I have replaced the Cam / Lifters in my 2013 Ram 1500. I replaced cam, lifters, oil pump, water pump, sparkplugs, cam position sensor, VVT solenoid, cam phaser, timing chain & accessories. Upon start up the truck will not run. The truck will turn over with no issue but will not run. I...
  14. okmitch77
    2013 no power, no start
    Hey all, I have a 2013 1500 5.7 with a no electric, no start condition. Turned the truck off to go to the post office, came back and opened the door and I do not have my gauge cluster, lights, and no click or anything when i try to start. Got battery tested and its good. I have noticed one thing...
  15. D
    Crank, no start unless held in "crank" key position.
    So I was driving home from work and my 83 W150 quite running. It hiccuped a few times then quite. Lucky I was able to coast into an O-Reilly's parking lot. After that, iIt would crank but not start, so I replaced the ballast resistor (BR), no change. So I did some checking around and testing. In...
  16. C
    No Start _ Question
    Hey Guys, Sorry if this is in the wrong spot. My 2018 won't start. Battery is fine and I tried a reset by disconnecting the negative for 20 Minutes. It doesn't try to start and I get a bunch of error messages; Faulty Power steering, Faulty Airbag, ect. I assume it might be a fuse just not...
  17. Jademoon1981
    02 ram 4.7 4x4 no crank no start
    Has been running decent with only 1 code for an O2 sensor. Went to work came home and parked. Went to run to the store and no crank. Putting key in ignition with door open dings, dash, radio, head lights, done, heater fan all turn on. Turn key over and no crank at all. First thought maybe...
  18. W
    2016 5500 RAM 6.4 No crank/no accessory/no start/full of errors
    2016 5500 6.4 automatic transmission Didn’t know proper forum to put under because heavy duty + electrical Shut truck off one night & went to start it the next day - had multiple error codes after being clear The night before Has had PCM replaced previously for different issue (AC failure + no...
  19. G
    Crank, no start & no spark - ASD relay not making connection
    I have a 2003 Ram 2500 5.7l hemi that will crank but not start. For the last couple months it has been hard to start, I have to crank it for 5-10 seconds before it fires up. I thought the CPS was going out so when it wouldn’t start at all I replaced the CPS and nothing changed. I tested for...
  20. L
    Dodge Ram 1500 5.7 hemi no start
    My truck cut off on my while driving after several attempts I got it start and drove home struggling to keep it from stalling. It would start after a great deal of effort but it ran really bad no power , missed awful,sucked down gas and my oil gage would drop to zero. Now it won’t start at all...
  21. K
    What is this orange two-pin connector?
    Hi Folks, I am fighting a no start condition on my 2004.5 Cummins. I am wondering if the culprit is the orange plug shown in the picture below—sitting on top of the fuel filter? Anyone know what this is and what it should be connected to?
  22. Dustin Lloyd
    Truck won’t start unless jumper is connected.
    I have a 2012 ram 1500 4.7. The only thing I’ve done to it this year has been replaced the tail light bulbs with LED bulbs. This issue has slowly been getting worst. At first I could run the fuel pump a few times prior to trying to start and it would always fire up. It has gotten to the point...
  23. N
    Fuel Delivery Problems
    Hi, I am new to the forum, but will hopefully be an active member. I own a 1998 Ram 2500, V10, 2wd extended cab, and it has been pretty reliable so far until..... I went to a meeting last Monday and the truck was running fine. I came out after and I turned the key, but let go before the...
  24. truckmen
    '96 2500 plow truck won't run after sitting the winter...
    Hey all, I parked my '96 Ram and hadn't started it all winter. Came out on a warm spring day to start it. It actually started fairly quickly and ran for about 2 minutes, was smoothing out and just beginning to warm up when it suddenly died. Tried several times to restart it to no avail. It...
  25. A
    '14 Longhorn 6.4 CTD no start
    HELP! I used my truck, 2014 Longhorn 6.4 CTD, this morning to run a short errand. Got home and the truck sat for about 5 hours. Just went go somewhere and it won't start. I have the passive entry with the push button start and when press I the brake and push the start button I can hear relays...
Carbary
