04 Ram 1500 Sport lift
Ethanlogan99
Hey guys, I have a 2004 Ram 1500 Sport. I would like to put a lift on it and probably 35's. What size lift should I go for as I would like no or very little rubbing. It's factory set up with 20" wheels, and I may look for some 20's or maybe 18's or 17's. What would the best lift be for that?
STyner
4.7L
I just leveled my 04 Laramie and am running 315/70/17 +20mm offset with 1/4 inch spacers in the front so the tire wouldn't rub on the upper control arm. If you go with negative offset rims you shouldn't need spacers to avoid rubbing.
