08 Ram, Stock 20's, 2" Level, and 35's w/ flares...
DeputyDipShizz
Pennsylvania
What size spacer should I run to avoid rubbing, and look the best to fill in the flares?
Sent from my EVO using Tapatalk
Bully's Performance
what style of flares do you have? also spacers are not recommended as they stress the joints a lot, it would be much better and safer (especially if you off road) to get a proper offset rim.
Thanks
Jeremiah
DeputyDipShizz
DeputyDipShizz
Pennsylvania
They are a short flare, maybe 2" wide and smooth
NWRQC
deviating away from the factory wheel specs (offset, width) with a lower offset regardless if it's via a wheel spacer or by running a lower offset wheel, will add more strain to the front end components. They both push the wheel center line out further from the hub, thus adding more strain on the hub and bearing.
With that said, how wide are your 35's? How do you want the wheels to sit, flush with the fender, stick out slightly, recessed in slightly?
DeputyDipShizz
DeputyDipShizz
Pennsylvania
I'd like the tires to sit even with the flares...I don't have 35's yet just getting a plan together
ChloeBrooks
