1/4" spacers
GreenGoblin
Lucedale MS
Anybody running 1/4" spacers with 12.5 wide tires I'm curious to if you have any vibration or rubbing issues
Sent from my XT907 using Tapatalk
tkyle486
no vibration but some rubbing.
GreenGoblin
GreenGoblin
Lucedale MS
I sure hate to pay all that money for new tires and have em rub
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I am running 1/4" spacers with 305/55/20 tires on stock wheels and they work fine. No vibration, and the tires don't rub anything.
GreenGoblin
GreenGoblin
Lucedale MS
Where did you get the spacers? I see a lot of guys running the motorsports-tech but they sure are high
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I'm running the Gorilla SP603 spacers. These are only about $5-$10 each, so they aren't expensive.
GreenGoblin
GreenGoblin
Lucedale MS
What is the difference? I understand you get what you pay for but the ones I looked at were 220 an that's crazy for a 1/4" spacer
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
You may have been looking at the larger spacers that have new lugs. This is not necessary on such a small spacer. At only 1/4", there are still plenty of threads on the stock lugs for the wheel to stay secure.
GreenGoblin
GreenGoblin
Lucedale MS
Well buddy I sure appreciate it you just saved me about 200 bucks
Searay245se
BrookPark Ohio
2015 Power Wagon Laramie
Thanks from me too.This is the exact info I have been looking for.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Just for reference, here is what the 1/4" spacers look like with a stock wheel and 305/55/20 tires...
Bluesmoke91
2nd GEN Site Mod
Baldwin Park, California
I already have a -12 offset wheel, would a 1/4" spacer be recommended. I heard it can put stress on the hubs. I imagine it's no different than running a -24 offset for example.
Sent from my DROID RAZR using Tapatalk
bouf0010
man that looks good - I might have to pick some up just for the look!
Sent from my SGH-I317M using Tapatalk
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I actually didn't want to run the spacers, but it was just too tight of a fit with the wide tire and the stock control arms. I had about 1/16th" of clearance between the back of the tire and the upper control arm, but it would touch when I turned the wheel. These spacers pulled them out just enough to clear without making them stick out too far.
GreenGoblin
GreenGoblin
Lucedale MS
Are the spacer you have hub centric? Everything I keep seeing says they need to be or it could put a lot of stress on the studs an eventually damage them
mel5151
2010 Ram Laramie 4x4
I am curious too. I am buying -12 offset wheels and I thought I wouldnt need spacers at that offset to get a 12.5" tire in.
HLram
2012 and 2007
Hemi 5.7 in both
Matt, are you running them on the rear, too? And are your wheels stock? I quit running 305s last time I got tires because they rubbed at full lock turning left only.
Nevermind, I finished reading the other posts and saw your picture. Sorry
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Yes, I am running them front and rear because I didn't want the fronts sticking out more than the rear. I also have the stock chrome clad wheels. I have had this setup over 100mph 3 times now and have not felt any vibrations with the cheap spacers. Here are 2 pics with the new rear drop coils showing how much the tires stick out of the fender with the front/rear spacers installed...
Sic&tatted85
2016 Ram 2500 Outdoorsman
Will 1/4 spacers work on the stock rims with the toyo or nitto's 35x12.5x20 or will I need bigger spacers
