1.5 body lift with OEM flares install question
Tpearson515
Saco, Maine
Hey guys, was just curious I installed a 1.5 body lift on my 2015 express that did not come with flares, I ended up installing flares after the lift. My question is I now have a 2019 classic with OEM flares, to anyone that has oem flares and installed their lift , did you need to remove your flare completely? Or did you just remove the adhesive up front? Or did you even have to mess with it?, its been a while since I did the install and can't quite remember if that piece the flare attaches to can be seen separated from.l the bumper or comes off during install?
Thank you for any insight!
Sent from my SM-N975U using Tapatalk
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
should be no reason to remove flares. the lift on my '16 didn't require anything on the sides, only the bumpers and those went right back tight to the body.
Tpearson515
Tpearson515
Saco, Maine
Ok thanks, my 15 was a little different in the front bumper I had to remove the headlights when i pulled it, this is a classic warlock I wasn't sure if that piece below the headlight had to come off as well, actually just watched a video of a guy removing his front bumper on a rebel which looks pretty close to this, and it looks like he didn't gave to pull the headlight or move that at all. Just want to make sure the zone ZOND9150 kit will work with this. e4f6d78a6bcf8515875e516206f82976.jpg
Addicted2fishing
Durham region
HEMI 5.7
Are you talking about that piece right under the headlight? If so, to me it does not look like you’d have to remove that. Send zone an email and tell them you have the rebel bunper and they should be able
To tell you!
