1.5 body lift
Barry Phillips
Fenton MO
Will a 1.5 body lift create a gap between bumper snd body? Currently have 6 inches of lift on my 1500. If so, how do you fix or have that not happen!?
BOWERSFJ
Uniontown OH
Body lifts have brackets to relocate the bumpers
Barry Phillips
Barry Phillips
Fenton MO
Do you think there would be any issue with brush guard I have on truck right now. Was trying to find a thread with someone who’s installed one with a brush guard on their truck and see if they caused an additional trouble
8SpdHemi
Canada
I have a 6" suspension and 3" body lift. Just make new brackets that move your bumper up and back inline with the body. Thats what I did with my westin contour bullbar.
Hawkguy
Al
Cheers.View attachment 238381
8spdHemi, I am assuming that you removed the portion of the fan shroud that encompasses the radiator fan? If so, did you notice any reduction in cooling? I am wanting to install a 1.5” Body Lift and I know the radiator fan will no longer match the Shroud.
GIJoe2010
No sh*t, there I was . . .
Killeen, TX
I did the Zone 1.5” body lift and removed the bottom portion of the shroud (per the instructions) and no issues with cooling.
8SpdHemi
Canada
I haven't noticed any change in the trucks cooling ability? Everything seems to be operating normally. But I also live in a cooler climate up here in Canada !! Lol. Summer temps are around 25-30 and those are hot days!! Hahaha
Hope this helps.
Cheers.
DILLIGAF
Canada
I am assuming that you removed the portion of the fan shroud that encompasses the radiator fan? I.
chuck in in the trash along with the ****** v8 fan and clutch fan. and do the V6 eFan swap
Hawkguy
Al
I have read A LOT about this…. Even contacted FF DYNAMICS to see if they had a fan kit for my 2018, they do not. I do moderate towing (up to 6K LBS) and have read on here that the eFan cannot guarantee sufficient cooling under heavy loads. My understanding is that the radiator on the eco-diesel is different than most 5.7. What’s your opinion?
Hawkguy
Al
Hope this helps.
Cheers.
I live in Alabama and we routinely see 36-37 deg C in the summer, sometimes 38+! Yeah, it’s hot!
8SpdHemi
Canada
If I could give multiple likes for one post....
Thanks a ton!!
I wasn't sure how much this would help, if any at all! Glad it did help you out, best of luck...post some pics when you get it all done.
Cheers.
8SpdHemi
Canada
Temps like that and I'd go find a lake and stay there!! I think it would be pretty easy to make a custom fan shroud for the bottom half to help direct the air flow...I'll mail you some ice cold snow (we still have some) to help keep you cool!!
Cheers.
Tskmk2
Montreal
2021 classic
Did you made new bracket or need to mod one from towhook to fit? I really want adding 1.5 to mine but want towhook
Joey93
