100,000 KM Tune Up
jeringate
Toronto, Canada
Just wondering what you guys are doing for maintenance when you guys are getting this far? (I have a 2010 5.7 Hemi)
For the spring (as I'm not at 100k just yet) I was thinking of doing the following;
- Plugs
- Sea Foam (with oil change right after)
- Drain and refill Coolant
Is there anything else I should be checking or doing?
Clean and inspect throttle body maybe?
Air filter if it needs it?
NYCruiser
Yonkers, NY
Transmission/diff/transfer case service, inspect all suspension/front end parts(all bushings, front and rear, and ball joints, tie rod ends, etc), brake fluid/power steering fluid.
Haven't owned a Ram that long before, but these are things I usually do on other vehicles I have kept that long.
