110/120 volt plug
jljbtm
Does anyone know how strong this Outlet is? my question is will it charge my laptop battery.
My wife's Ford did not charge the laptop as it kept blowing a fuse Ford said it wasn't strong enough to do that job.
Sent from my SM-N950U using Tapatalk
1500canoe
Central Pennsylvania
Mine is labeled with writing on it saying 150w I think. Most laptops consume less than 1/3 of that as far as I know.
jljbtm
jljbtm
thx for pointing that out, my laptop does say 65w COOL.
Those Fords must be less than 65w
rotwiler
Washington
For charging should be fine. I tried a dremel tool and was too weak.
Random_Walk
...what's this bolt do? *plink* ...oh.
Out
2017 QC 4WD SLT
Pentastar 3.6
Like they said... Should work, unless your missus has some sort of fire-breathing Alienware gaming rig.
Even my 15" MacBook Pro happily works and charges off a cheap inverter plugged into the cigarette lighter outlet.
One thing to keep in mind if It's too weak; have her recharge it while not using it, then use it on battery alone once charged.
Bramo
