-12 or -24 Offset?
Danny0894
Hey Guys, I just leveled my 2010 sport, going to get new wheels and tires, going with 35x12.50r18 BFG K02, what offset should i go with? -12 or -24? any opinions?
D
Danny0894
I haven't fully decided yet, probably a 18x9 though
sbuko213
Arcadia, FL
6.7 HO
You should be fine with a -12 unless you want a wider stance.
D
Danny0894
I'm not really worried about clearance, just looking for opinions on which will look better. Thanks,
sbuko213
Arcadia, FL
6.7 HO
Gotcha. -24 will stick out almost 1 3/4" over stock. Stock offset is +19 on the 20s. This will give you a good meaty stance if that's what you're after.
D
Danny0894
Would this not make it stick it out 2.5-2.75 because of the addition tire width as well? or am i doing math wrong somewhere?
42mm difference with rim+ the additional inch of tire?
sbuko213
Arcadia, FL
6.7 HO
I just did that math based on converting the offsets to inches, so the center of the wheel will be sticking out that far. If you add the extra tire width you're probably at 2.25-2.5 I'd guesstimate since you're not really changing the width of the wheel.
D
Danny0894
Ok perfect, any personal preferences as to which way i should go? I'm sure they will both look good, because its only a half inch difference either way, but still looking for opinions before i pull the trigger
charonblk07
Calgary, Ab
F1-A forged 349ci
Stance is a personal preference, but you also need to take into account local laws which may stipulate how far out an uncovered tire is allowed to stick, which is why fender flares were invented. The -12 is generally OK in most places, -24 requires flares in many areas.
sbuko213
Arcadia, FL
6.7 HO
Definitely check the local laws. You'll be fine either way.
Saleen5150
