13+ Homelink module
Status
Not open for further replies.
Hankrebel
Mississippi
Cummins 6.7
Im looking for just the module and not the entire bezel.
I tried an older module in my 2016 but it wont work.
Ricks Ram
You will definitely need a 13 or newer. They are a little harder to find than the 09 to 12. The best place thing to usually do is buy the entire overhead console used if possible and switch over any parts you don't want like the rear slider switch. Make sure it doesn't have the sunroof switch. There is no block off plate for it like there is for the rear window slider. The best place to find them is Ebay and Car-Part.com.
Sent from my SM-G981U1 using Tapatalk
Hankrebel
Hankrebel
Mississippi
Cummins 6.7
Yeah I actually got a bezel with the sunroof switch and sliding window switch from another member here.
The sunroof switch is not hooked up obviously but doesnt bother me if its there.
I will check those thanks.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
it available, if you still need it text me or Whatsapp me +13473438125
Sent from my TECNO B1 using Tapatalk
He doesn't have one @Hankrebel , this is a scam
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Hankrebel
Hankrebel
Mississippi
Cummins 6.7
Yeah I figured as much when they didnt want to use paypal. They wanted to use two other payment apps that I never heard of.
Thanks for the heads up though!
Status
